Scratch Build – In Progress Hibernation - SFF sleeper build
Discussion in 'Project Logs' started by Goatee, 21 Dec 2020.
  1. Goatee
    Goatee Multimodder
    19 Apr 2015
    When I think of something hibernating, I think of a warm toasty sleeper.
    Thats what I'm working on here.
    Its a 2000w space heater, looks relatively old but in pretty good nick.
    The back is just asking for a hole to be cut for an IO shield and GPU bracket.
    Flipping it over I got a lot of screws to go.
    Heater element and front guard (more screws)
    Guts being removed
    Importantly the measurements (340 x 190 x 100 mm's) that's a good size at just under 6.5L
    I might need to move the front grill forward to get a board in, something like this
    Here she is with a helper to remind you what she looks like
    Aytos, Jonathan Craig and Arboreal like this.
  2. Modultra
    Modultra What's a Dremel?
    1 Jul 2020
    I was thinking that it was one strange vacuum cleaner at first.
    Goatee likes this.
  3. Cheapskate
    13 May 2007
    It even has a little trough for wires. :D
    Goatee likes this.
  4. Goatee
    Goatee Multimodder
    19 Apr 2015
    Made some progress so here are some more shots:
    Everything laid out:
    Another angle:
    Current Specs
    • I5-9500T
    • GTX 1650
    • PIO motherboard (power via 240W laptop charger in rear IO)
    • 1TB Crucial SSD
    • 32gb of DDR4
    • Pair of Nocuta 92mm Fans (Slightly mangled from previous modding)
    Printed a new IO backplate before breaking my printer - Eeek
    Doesn't she look nice!
    Testing some WC components
    Cheapskate, BeauchN, IBMer and 3 others like this.
  5. jinq-sea
    15 Oct 2012
    Ooh. Nice!
    Goatee likes this.
  6. Arboreal
    21 Jan 2011
    Looking good there @Goatee, cheeky little PIO action!
    Even better, It'll be blowing 'hot' air out of the front as per the original design :D
    Goatee likes this.
  7. Goatee
    Goatee Multimodder
    19 Apr 2015
    I have some server based 40mm fans that I could rig up to the rad and connect to one of the original switches to disable the PWM signal enabling them to go to 11 (which is deafening).
    I have so many options.
  8. jinq-sea
    15 Oct 2012
    What's that lump of Alphacool epicness?
  9. Goatee
    Goatee Multimodder
    19 Apr 2015
    The quint 40mm rad or the pump res?
  10. jinq-sea
    15 Oct 2012
    Oh it's a 40mm rad? love it. That's cool!
    Goatee likes this.
  11. IBMer
    IBMer Minimodder
    5 Jun 2015
    Ohoh, nice to see that slim alphacool rad in action!!
    Goatee likes this.
  12. Aytos
    Aytos Minimodder
    9 Aug 2020
    I'm curious how this 40mm rad turns out. I contemplated even using those rads in my build, but TDP of parts I have is way higher than yours. I dropped the idea, since my thinking was if I was to use tiny fans (which kinda defeats purpose of quiet operation with water cooling), I could accomplish the same with air cooling at fraction of the cost.
    Goatee likes this.
  13. Cheapskate
    13 May 2007
    I didn't think you could do that without the rig going into panic mode. -Neat.
    Goatee likes this.
  14. Goatee
    Goatee Multimodder
    19 Apr 2015
    guess we will see, haven’t tried it yet
