CPU How long without a cooler before damage?
Discussion in 'Hardware' started by Ramon Suey, 7 Nov 2012.
  1. Ramon Suey
    Ramon Suey What's a Dremel?
    16 Dec 2011
    Quick and easy. Can I test a M/B and i3570 without a cooler - booting only into Bios. Will it overheat, if so how long? The reason I ask is that I am awaiting a new M/B (Gigabyte Sniper M3) and before I fit it, having just returned one dead. I want to test it works first of all. I intend using only 8Gb Samsung Green and the video output from the i3570 - is this OK?
  2. Parge
    16 Jul 2010
    How long, erm, about 0.00001 seconds.
    DONT DO IT
  3. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Not really. I would say you only have a few seconds before you start seeing smoke.
  4. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    As others have said don't do it.
    Mind you I accidentally fired up a pc with an AMD X2 without the cooler in place and it took a few seconds for the penny to drop regarding what I'd done and a second longer to hit the psu off switch. The cpu heatspreader was barely even warm to the touch.
    When I mentioned this on the forums a while back I was informed that the thermal cut off would kick in before the chip fried anyways.
  5. Deders
    Deders Modder
    14 Nov 2010
    Do you have a cooler you can hold onto the cpu while you work, so long as you don't do anything intensive you should be ok with this. Since CPU's started clocking themselves down they tend to be a lot cooler
    We flash bios's and test boards quite a bit with this method, it only tends to be the pre 64-bit cpu's that heat up significantly.
  6. Ramon Suey
    16 Dec 2011
    0.00001 seconds doesn't give me very long! I found it easier putting the cooler (Xigmatek) backplate on when in the M/B was in the case. I understand the Intel stock cooler is awkward to remove. Thanks Deders for the suggestion.
  7. Chicken76
    10 Nov 2009
    Not at all. You just rotate the four pins by 90º counterclockwise and they might pop out on their own. If not, just pull gently on them. That's all.
  8. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    if it's only for a minute, you could use any old heatsink (from a mobo, old cpu, etc) or even a large chunk of metal, just be carful not to short anything out.
  9. faugusztin
    11 Aug 2008
    Why don't you use the stock cooler in meantime ?
  10. rollo
    rollo Modder
    16 May 2008
    If you do try this id recommend you stand by with a fire extinguisher and a video camera.
    1 is for the fire you put out and the 2nd is for the you tube video that we all want to see.
  11. faugusztin
    11 Aug 2008
    Wasted time. You could turn CPU into smoke only with a very old AMD CPU's. Intel even in those early '00s had a overheating protection, and still has. The only thing you can capture on camera with a Intel CPU without cooler is your computer turning itself off very quickly.
  12. Ramon Suey
    16 Dec 2011
    Thanks for all your contributions. I do propose to test the M/B out of the case putting in on a cardboard box. I will use the stock cooler for the test. I have watched the removal on Youtube and it does seem easy enough (I didn't use the stock cooler on my previous build (who does?). Clearly without cooling, the CPU won't stay on long enough (assuming it doesn't fry) for the M/B to boot into EFI. When I receive the replacement M/B from Amazon, I will report the outcome.
  13. Shirty
    18 Apr 1982
    Everyone in this thread is wrong.
    Of course you can use a CPU without a heatsink, you will just need a large container of chilled water that you must steadily pour over the exposed die whilst power is on, thereby negating the need for a metal-based thermal solution.
    If anyone actually follows this advice, they deserve the financial/electric shock they will receive, as well as an honorary Darwin award. Use a HSF & stay safe kids.
    Kiliv likes this.
  14. Parge
    16 Jul 2010
    No, I mean, your right, my system is watercooled so I have a hose from the garden that just pours water straight onto the CPU die.
  15. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    /This Thread
    You can probably check it posts, if you leave it on for longer than that the CPU will hits it's overheat protection limit and it will shut off again.
  16. Shirty
    18 Apr 1982
    For extra points, place your index finger on the die to see why a heatsink is really rather important.
    Quadruple points if you replace the finger with any part of your manhood.
  17. Dudey109
    Dudey109 Minimodder
    20 May 2010
  18. faugusztin
    11 Aug 2008
    The last AMD CPU models to die from heat were about a decade ago :
    Intel had overheat protection even then, AMD joined not long after the video above was created and published on Tomshardware.
    In short - the only way you can currently kill a CPU is overvolting it, or physically destroying it.
  19. Deders
    Deders Modder
    14 Nov 2010
    Like I said before, when we do lots of bios updates in a row for modern motherboards, we tend to just hold a heatsink on the cpu for old times sake, they barely even get warm at this stage. If booting into windows it might be a different story.
  20. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    CPUs barely get warm because they have heatsinks on them, LOL
    From the instant you power on your system, the CPU is getting voltage and current and needs to be cooled by a heatsink.
    /thread
