CPU How long without a cooler before damage?
Discussion in 'Hardware' started by Ramon Suey, 7 Nov 2012.
  1. Deders
    Deders Modder
    14 Nov 2010
    We hold the heatsink on without any paste and neither get warm, on an older chip it's a very different story, cpu gets too hot to touch, even after using a heatsink.
  2. Ramon Suey
    Ramon Suey What's a Dremel?
    16 Dec 2011
    Thanks Shirty. I'm a bit wary of watercooling that's why I bought a Xigmatek Aegir. I considered Corsair but I think your solution might be cheaper?
  3. Shirty
    18 Apr 1982
    Oh it's definitely cheaper, you probably have a high pressure tap and a length of hose to hand, all you need is to put the whole rig in the bathtub to allow the used "coolant" to drain away and you're good to go.
    Or you could put the plug in the plughole and go for a bit of immersion cooling :hehe:
  4. TheDodoKiller
    TheDodoKiller Minimodder
    23 Oct 2011
    Why not just blow on it tenderly?
  5. Ramon Suey
    16 Dec 2011
    I now have a basic system up and posting to BIOS/EFI - I have yet to add the SSD and 3 HDDs and fix up the case headers - tomorrow. To test I installed the i3570K into the Sniper M3 mATX M/B (second board, first DOA) using the stock cooler without TIM - to save having to clean and reapply when I install my Xigmatek. The temp settled at 50c - so it is clearly OK to test without TIM. So Deders is clearly correct. PS to TheDodoKiller - I'll ask my wife if she can do it.
  6. Deders
    Deders Modder
    14 Nov 2010
    Yay me!
  7. RagingMadman
    RagingMadman What's a Dremel?
    6 Oct 2012
  8. rollo
    rollo Modder
    16 May 2008
    It's real on older chips without modern safety limits.
    To sell a CPU in the eu these days you have to meet safety regulations and one of those regulations is a thermal shut down on the pc if one part goes to high.
    You could technically speaking use butter as your Tim its better than some of them on the market.
