Hardware How many CPU cores do games need?
Discussion in 'Article Discussion' started by Sifter3000, 5 Jul 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. aLtikal
    aLtikal 1338-One step infront of the pro's
    7 May 2008
    Interesting myth buster :) Good article. In other words, Duel Core is fine for now, but If you game & multi task and your getting a new PC, get Quad core.
  3. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Interesting read. You should suspect that by now, after six? years of having duo/quad core technology. Games would be more multi core capable by now. Seems that they could offload much of game calculations back to the CPU instead of GPU. Or is it because more and more game related calculations are done on the GPU leaving the CPU doing nothing much?
  4. aLtikal
    7 May 2008
    Bad company 2 is very CPU intensive, so i wouldnt say ALL games are doing most there calculations on the GPU
  5. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    It's more or less what I expected. I'm still on dual core because I'd seen nothing to warrant any more than that. I feel vindicated hurrah! I shall stick to my plan of leaving it another year or 2 before I go quad core.
  6. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Dirt 2 can't run on single core? 0.0, interesting trivia.
  7. Tyrmot
    Tyrmot Minimodder
    12 Mar 2008
    Over 9000!!!!
    /meme
  8. Farting Bob
    Farting Bob What's a Dremel?
    21 Jan 2009
    How did you only enable 1 to 5 cores to run the game on using the 980X?
  9. leveller
    leveller Yeti Sports 2 - 2011 Champion!
    1 Dec 2009
    Great article, many thanks. It's the sort of question hat runs around my mind most days!
  10. Guest-16
    Guest-16 Guest
    In the Gigabyte BIOS of the X58A-UD7 mobo you can specify how many CPU cores you want it to use.
  11. Oggyb
    Oggyb Mutant
    15 Jun 2010
    Wasn't there a major debate a few years ago about the relative merits of coding multithreaded gaming applications? I seem to remember things such as race conditions and the linear cause/effect simulations in most games being a hindrance to developers taking up this new technology.
    Does anyone have more info on this, and possibly an opinion on why the games tested don't scale beyond three cores?
  12. Jipa
    5 Feb 2004
    Kinda makes me feel bad for the fools who've paid the i7-premium for their gaming-only rigs. Seems like a heavily overclocked Wolfdale would still be all it takes to keep gamers happy. And at the very least it seems like budget builders should just forget about the extra cores and spend more money on the graphics.. Kinda what I've thought, I just didn't know it was such a clear cut.
    Thanks for the article, very interesting indeed.
  13. HyBry
    HyBry What's a Dremel?
    13 Feb 2008
    I would suggest returning to this test and do it again, but this time try underclocking the CPU to see the multithreading in real action.
    In order to see the benefit of multithreading CPU has to be the bottleneck, but in all these tests after enabling third core GPU becomes the bottleneck. You are not gonna see much improvement from 3 to 6 cores if GPU is the limiting factor. Or you should be looking more at CPU loads with differnet amount of cores enabled.
  14. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    Essentially from that your saying that the G6980 or i3 530 are the best CPUs for games at the moment/AMD equiv parts??
    Id noticed a speed bump running an 530 at 4.8ghz vs at 920 at 4.2ghz myself and you have by this confirmed my thoughts.
    Well, that makes me happy as I have been reluctant to sell up my x58 in favour of a cheap i3 system (1 to save on power and 2 because I dont bench anymore).
    Nice results,
    Cheers!
    Andy
  15. memeroot
    memeroot aged and experianced
    31 Oct 2009
    alternatively 6 cores means you dont have to faff around closing stuff down...
    what is heavy multitasking btw... when working have perhaps 20 apps open at a time + 3 database servers, many active and with chrome with flash enabled you could double that... whats the actual break down....
    btw I only just moved to a quad and its a clear improvement from the old dual core I had previously which was horrid.
  16. BlackMage23
    BlackMage23 RPG Loving Freak
    4 Aug 2006
    Good Read.
    I'm still using a old E6600 with a GTX280, it runs everything fine and I see no reason to upgrade any time soon.
  17. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    no SupCom test?
    supcom was always good at beating the crap out of my quad, i'd like to see if it can handle a hex core too :p
  18. Guest-16
    Guest-16 Guest
    In a perfect world, yes I'd have images for all of them, but it quite long to setup it all up, play the game as it should be and then quickly alt+tab to get a good screenshot - getting 6 results for each game would have taken 6x as long. It was just impractical :/ Looking at all six together tells you where the game stops using cores though, so you can infer from that.
    I'd love to have done more but it took nearly 5 days to manually play all these games and get consistent results. :( I might have another go after Starcraft 2 or Civ 5 comes out - test those, Metro 2033, Blur, ARMA II update (if I can get hold of it out here) and whatever else looks interesting.
    Hamish - Supcom is ooooooooooold dude. At least people still play CoD 4 MP.
  19. Salty Wagyu
    Salty Wagyu moo
    5 Jul 2010
    I wouldn't be so quick to say we shouldn't upgrade our CPU for a performance boost. I used to ran a Core 2 duo at 2.66ghz for a dual core game - World of Warcraft, at 25-35fps, now I get 50-60 with my new Intel i5-750 at the same 2.66GHz with the SAME graphics card from my previous system, the Geforce 260 SSC.
    If anything, it could be the CPU architecture that improves things rather than the number of cores it has.
  20. leveller
    1 Dec 2009
    As a side-by-side kind-of comparison, it would be interesting to then add to the article the dedicated multi-threading apps (encoding, etc) that do try to use all cores. I know we have access to that info through the CPU tests in the mag etc, but to actually lay that side-by-side would be revealing. I guess it will likely show the slow take-up and usage of many cores for gaming?
Tags: Add Tags
