Displays How to turn off monitors built in scaling...
Discussion in 'Tech Support' started by DLoney, 30 May 2009.
  1. DLoney
    DLoney What's a Dremel?
    21 Feb 2005
    Its grayed out in the Nvidia control panel...
    I have retried installing the drivers- no go. There is no option under the OSD to turn it off...
    any ideas? Im trying to play Empire: Total War at a lower res without it being blurry. (lookin' for the black bars)
    :eyebrow:
    http://yfrog.com/58flatpanelscalep
  2. Krikkit
    21 Jan 2003
    Give us a clue...
    What monitor are you using?
    What have you tried?
    Have you done a google?
    What are you connecting to your graphics card with?
  3. GoodBytes
    20 Jan 2007
    At least we know 1 thing after some investigation.
    He run either Vista or Win7 because the item selection of the tree is not dark blue.
  4. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Normally its in the monitor's own push button menu, that's if it supports 1:1 opposed to scaling.
  5. Andersen
    Andersen Morally questionable and ethically wiggly
    25 Nov 2002
    Lower the desktop resolution temporarily. You can then change the Nvidia scaling option.
