HPRES III MEGA Complete, ty all.
Discussion in 'Project Logs' started by Defyant Mods, 3 May 2005.
  1. ZuNe
    ZuNe What's a Dremel?
    2 Jun 2005
    Flawless bondoing :dremel: :thumb:
    That fanbox looks so smooth!
    Nice ;)
  2. BiG Kahuna
    BiG Kahuna What's a Dremel?
    14 Aug 2004
    you sir, are the bondo-god :rock: :D
  3. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    I have read this thread now, and i have been inspired. In fact, i am currently typing with the nearest thing that the UK has to bondo drying on my fingers. Thankyou.
  4. jasonmason
    jasonmason What's a Dremel?
    5 Sep 2004
    Wow... Amazing.
  5. otispunkmeyer
    otispunkmeyer What's a Dremel?
    4 Mar 2005
    what is the nearest thing we have to bondo?
  6. frodo
    frodo What's a Dremel?
    1 Nov 2003
    We have P38, davids isopons have p38, p40
    Easylite and Metalix are my favourite, both easy to sand and shape
  7. djfrexx
    djfrexx What's a Dremel?
    27 Dec 2004
    nice.... looks intresting
  8. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    looking spiffy
  9. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    thats cool.... um anyone have any pants i can have??? :D
  10. mandy_modded
    mandy_modded Minimodder
    12 Mar 2005
    Draeth1 K&H (brand) spray putty is available thru most auto departments & stores (at least in Australia)
    I'd suggest you ask at an auto paint store or the auto section of DIY stores
    It is more like spot putty than bondo, usually you'd use
    bondo (thickest) then
    spot putty (thin layer) and lastly
    spray putty (very thin layer) for the final coat before applying the paint primer.
  11. Guest-6374
    Guest-6374 Guest
    Bondo is a brand name auto body filler in North America, so any other body repair material should work equally well.
  12. will.
    2 Mar 2005
    i'm not sure what the name of the stuff i'm using is, but its easy enough to sand and sticks to everything, including skin as i discovered yesterday. Its also slighty rubbery so any flexing while making the case does not cause its to crack. I should have taken some pics i suppose, but i'm almost done now. I'll put a bunch of pics up later mebe.
  13. sirbogey
    sirbogey What's a Dremel?
    7 Jun 2005
    intersting stuff, but slightly to time consuming for myself..
  14. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Excellent work Defyant; you inspire me to do my own work... if only I had tools and money :sigh:
  15. Firehed
    15 Feb 2004
    What can I say.... great work. It's simply amazing how you can start with any old case and transform it into a true work of art.
  16. waitandbleed
    waitandbleed What's a Dremel?
    4 Feb 2005
    defyant case looks sweet. just like the other one. sent you a pm a while back (maybe a week ago) and no response. So if you could check and respond that be greatly appreciated! Also keep up the good work. Its time for an update also :D
  17. G4m3R_X3r0
    3 Sep 2004
  18. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Didn't want to run the old metal back plate, so i thought i'd try something different. :D
    Stepping out to my favourite shop, i picked up a cut peice 8mm thick clear plex!
    A qik test to see it fits right, all the motherboard points and needed holes, mounts etc will be added later.
    The plex panel it self isn't the actual mod! but the idea to diffuse and light it is!
    the idea came to me while doing the front light diffusers, its just going to be on a much larger scale.
    A qik test on a small peice of off-cut confirms the idea will work.
    next is to sand the peice of plex with 1200 wet and dry, the small scratched catch the light beem and allow the whole flat surface to light, rather then just letting the light travel thru to the ends like on Hevy plex SLB mod i did for Zak.
    Adding some light.
    Once i could see that the effect was goin to work it was time to peel off the protective paper and get to work on my motherboard back panel.
    Simple wetrub in the laundry sink again with 1200 W/D and a 3M rubber hand block, all of 15 mins work and is done to both sides to achive an almost frosted look.
    The end result.
    Next is to hook up some lights for testing.
    turn off the lights and see if it works!
    i was pretty impressed at what a great internal light feature this simple mod makes,even with the motherboard and internal bolted in there will still be enuf see-able area to keep this a main feature inside the case.
  19. Cowinacape
    Cowinacape What's a Dremel?
    26 May 2003
    Looks good! Used to use the same trick to lite up windows in model railroad buildings as well. Looking forward to see some more of your work!
  20. venomz
    venomz What's a Dremel?
    16 May 2005
    hey DÈF¥âÑt¸.·´¯`¤ what kindalightsarethoughs that you use to lightthat window up? i kinda want to do the same thingformy windowim maken for my pc. for my windowim doing isim etching the inside window andhaveing a o0ut site window andi w ant to do that samelighting to light the etching up a bit.
