Overclocking [hwbot] Super Pi 1M Rankings!
Discussion in 'Hardware' started by Eliminos, 17 Feb 2006.
  1. fruit monkey
    fruit monkey What's a Dremel?
    1 Nov 2006
    [hwbot] pie_uk - 12.97 - Xeon 3060 4005mhz 2GB Cellshock @ 5,5,5,15 [/hwbot]
    of course......
    now if i tighten some ram timings i may get away with 12s
    as i said, i beat all of you lol
  2. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    good jop. dammit i gotta beat you too.
  3. zhangmaster12
    11 Jun 2006
    you gotta repost under your name. the username and the name enterd into fruitmokey's hwbot post are not the same, post your results UNDER YOUR NAME!
  4. Guest-18698
    Guest-18698 Guest
    well after some tinkering, i have smashed the 13s 1m barrier :) ! feels good >>
  5. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    [hwbot] play_boy_2000 - 18.781s - E4300 @ 3120mhz 8x multi 2gb OCZ 4-5-4-15[/hwbot]
    Clean install of Vista Home premium
    P5B-E
    390x8 = 2120
  6. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Bloody hell, i'm STILL 22nd! :D
    Woot!
  7. play_boy_2000
    25 Mar 2004
    oops, I accidently put 2.12ghz instead of 3.12 :blush:
  8. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    First go with my new pc :)
    [hwbot] Mr T - 16.960s - E6600 @ 3105mhz 9x multi 2gb Corsair 5-6-6-20 [/hwbot]
  9. trig
    trig god's little mistake
    10 Aug 2006
    [hwbot] trig - 15.313 - e6550 @ 3.29 ghz on air (ram limited) , 2GB Corsair XMS2 800 4-4-4-12 T1 [/hwbot]
  10. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    [hwbot] rocket733- 21.562s - e2180 @ 3.05 ghz on water, 1GB Patriot DDR2 800 4-4-4-12 T1 [/hwbot]
  11. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    mine was 26.596 seconds with an e4500 @ stock 2200mhz
    not to sure how to do screenies :duh:
  12. wyx087
    wyx087 Multimodder
    15 Aug 2007
    [hwbot] wuyanxu - 13.801s - q6600 @ 3.807 ghz 423*9 on Thermalright Ultra 120 Extreme, 4GB (4x1GB) OCZ Platinum v2 @ 4-4-4-12 2T, Abit iP35 Pro [/hwbot]
    :rock: oh yeah.
    but it isn't stable, after this, i ran Prime and crashed within 10min, temps are like 70,70,67,67. i need to either lap the Ultra120eX or get a better mobo with less Vdrop
    ah, so close to TimS...... but yay, fastest on air :p
  13. Ultimatum01
    Ultimatum01 Im new but no noob
    28 Dec 2007
    [hwbot] Ultimatum01 - 28.610 - AMD X2 6000+ @ 3.10 ghz , 4GB (4x1GB) Kingston Rubbish @ 5-5-5-18 2T, MSI K9n----NOTHING OVERCLOCKED [/hwbot]
  14. Krikkit
    21 Jan 2003
    Noes! I'll be out of the top-20 at this rate... :(
  15. Guest-23315
    Guest-23315 Guest
    [hwbot] '91 - 30.097 - AMD Opteron 146 Venus @ 3.00Ghz , 1GB Corsiar Value RAM @ 186Mhz, Ultra-D, Custom Watercooling [/hwbot]
  16. cpemma
    cpemma Ecky thump
    27 Nov 2001
    [hwbot] cpemma - 22.792s - E2180 @ 2.9GHz, Ninja B, 2Gb Corsair CM2X1024-5400C4, 5-5-5-15-2T - GA-P35-DS3L [/hwbot]
    Not bad for a £53 cpu & £27 RAM. ;)
  17. MixWizard
    MixWizard Minimodder
    16 Jan 2007
    [hwbot]MixWizard - 23.250s - Intel Core 2 Quad Q6600 @ 2.5ghz, 2GB Corsair Twinx XMS2 Pro, Striker II Formula[/hwbot]
  18. WhiskeyAlpha
    WhiskeyAlpha What's a Dremel?
    5 May 2006
    [hwbot] WhiskeyAlpha - 12.82 - Intel Q6600 "G0" @ 3.98GHz / G.Skill PC2-8000 - 434Mhz 5-4-4-12 [/hwbot]
    W00t! now I get top spot for a couple of days, 'til somebody with a Penryn comes along and whoops me :D
  19. Fused
    Fused Minimodder
    19 Jun 2007
    [hwbot] Fused - 15.125s - E6600 @ 3401mhz 2GB OCZ sli ready PC2-6400 Zalman CNPS9700 cooler (air)[/hwbot]
    Not as good as above but gets me on the leaderboard at no 10 (not bad FOR AIR, now must work on my overclocking some more)
    EDIT: 1/03/08 Gone a bit further and managed to get that, now going to stress test the system to make sure it is actually stable (Woo 800mhz free hopefully :worried:)
  20. cpemma
    cpemma Ecky thump
    27 Nov 2001
    OK, just to get in front of Rocket733 :p
    [hwbot] cpemma - 21.248s - E2180 @ 3.1GHz, Ninja B, 2Gb Corsair CM2X1024-5400C4, 5-5-5-15-2T - GA-P35-DS3L [/hwbot]
