News IBM Technology Alliance reveals 28nm chip plans
Discussion in 'Article Discussion' started by CardJoe, 17 Apr 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    I think we are starting to run out of space. whats after 28nm? you can only get so small before technology has to change to another format
  3. hodgy100
    hodgy100 Minimodder
    2 Jun 2008
    Picometer comes after nanometer :p
  4. Fritzr
    Fritzr What's a Dremel?
    5 Mar 2009
    Next step is 3D designs. Current chips are designed as a massive drawing on sheet of silicon. Though they are layered to allow connections to cross without leakage they are stillessentially a drawing on silicon.
    The next major change will be layering the current flat designs one on top of another with vertical interconnects.
    There are a few projects working on it, but not much is being said about the progress toward 3D chip design.
  5. dec
    dec [blank space]
    10 Jan 2009
    sooner or later we'll be talking about putting a whole processor on a single silicon atom XD. exactly how small is a picometer anyways?
  6. lp1988
    lp1988 Minimodder
    24 Jun 2008
    well for starters, there goes 1000 um on a millimeter and there goes 1000 nanometer on a µm. so we are talking pretty d*** small here
  7. Xir
    Xir Modder
    26 Apr 2006
    :confused: Why is this new? AMD and IBM have been working together for ages* in IBM's east fishkill facility...
    *well...ever since the AMD-Motorola alliance was cancelled
  8. MajestiX
    MajestiX What's a Dremel?
    14 Apr 2002
    so is amd skipping 32nm? pretty sure intel will follow through with it which by their calendar won't have 28nm till late 2011
  9. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    32 to 28 isn't exactly a huge leap...
  10. Toka
    Toka Minimodder
    19 Nov 2006
    Ive said it before, Ill say it again
    People underestimate the technical accomplishment of '45nm' or '32nm' etc. The closer we get to 16nm the more in awe I am.
    We will be looking at (pseudo) 3D chips at 22nm and more of Mott's 'Strange Metals' will be used instead of SiO2. 28 is 'simply' a refinement of the 32 materials and synthesis techniques.
  11. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    no doubt.. and you'd think the overclocking would be worse at a certain point from leakage
  12. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    28nm is a half node to 22nm. You are unlikely to see 28nm used in CPUs, AMD's next die shrink will be 32nm as per their roadmap.
Tags: Add Tags
