Other If you could give one part of computing a large generation jump foward, which bit?
Discussion in 'General' started by rainbowbridge, 10 Jun 2009.
  1. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
  2. Horizon
    Horizon Dremel Worthy
    30 May 2008
    motherboard/bus system. When people say the hard drive is the only component in the computer where little progress is made. I disagree, the motherboard hasn't made much progress tech-wise sure, new features have been added and removed over time just like a neglected OS, where vital improvements than can be made are overlooked. I like a system with reduced bottlenecks, and a theoretical maxium that is near achievable in a reasonable amount of time.
  3. Nexxo
    23 Oct 2001
    The battery.
    Everything starts with power. Even the fancy-pansiest CPU and storage don't mean jack without the juice to run them, and without portability. As portable devices use more and more power to do their wonderful things, the next bottleneck in technology will be compact, light batteries that recharge faster and last longer.
    Failing that:
    It would solve a lot of the power consumption and heat problems in one swoop.
  4. Journeyer
    Journeyer Minimodder
    31 Aug 2006
    The display.
    I'm a sucker for "swooshing" sci-fi holographic displays. :D
    But I'll have to agree with Nexxo; the batteries would be a great coup, unless the system at hand runs on mains juice. In that case the superconducting mains cables would suffice.
  5. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    This is true, so you do this:
    Pc's shouldn't be much bigger than a lunch box at worst by then, right?
  6. JaccoW
    JaccoW Overspender on keyboards
    30 Apr 2009
    @ Fisher: I already did. Earlier and subtle...
    It's a tinfoilhat thing. ;)
    Most of the hardware components would be unusable by you, but might give you and everybody else a giant leap in technology when taken apart and reversed engineered.
  7. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Sure some things haven't moved on for years but PCI-E, SATA, the virtual elimination of the FSB, etc.
  8. interzen
    interzen Real men use chainsaws.
    18 Feb 2009
    What he said ...
    Solar-powered desktop, anyone? I'd buy one ...
  9. UrbanMarine
    UrbanMarine Government Prostitute
    7 Aug 2008
  10. kenco_uk
    28 Nov 2003
    I'd grab a sporting almanac and possibly a hover board if I had the time.
    Actually, if tech had advanced far enough, I'd grab a portal gun.
  11. blighter
    blighter What's a Dremel?
    14 Jun 2009
    I'd use the computer to do a search and find out what I had brought back with me. Then I guess I'd have to take that. :)
  12. Elton
    23 Jan 2009
    As someone has mentioned before:
    A book full of lottery numbers, AND the cooling systems.
    I'd kill for anything else, but it really wouldn't be compatible...at all.
  13. Rum&Coke
    Rum&Coke What's a Dremel?
    23 Apr 2007
    Pervasively Wireless SOA: Want to be able to use a thin client to access my computer from the middle of the ocean both connecting wireless and powered wireless
