News Inside the Acer Revo
Discussion in 'Article Discussion' started by CardJoe, 27 Apr 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    sweeeet, perfect lil home pc stuck on back of a monitor
    mum's xmas present sorted
  3. p3n
    p3n What's a Dremel?
    31 Jan 2002
    The back of my TV gets really hot, not sure i'd stick more heat sources on!
  4. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    ooooooo there is more room in there than i thought, pleant of room for modding some items in there.
    Is it possible to hook up a Blue ray SATA drive to the e-sata port? i have only just had the thought, so forgive me if its a simple question.
    If its possible then a little modding could see an internal BD slimline drive installed!
    Acer stand to make alot of money on this, especially if the retail on the motherboards is going to be very high. The revo is extremely good valve for money.
  5. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Prices for the bigger ones? £250 would be more than acceptable, I'd say.
    If nicely priced this'd come very handy for Christmas indeed.
  6. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    How noisy is the fan at load? It looks perfect for a whats supp dawg car build!
  7. Guest-16
    Guest-16 Guest
    Super quiet from what I could tell. Much quieter than the Asus EeeBox
  8. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    how big is the motherboard in that thing?
  9. Turbotab
    4 Feb 2009
    E-sata BD yes, but mucho money
    http://www.kikatek.com/product_info.php?products_id=86986&source=froogle
  10. Burnout21
    9 Sep 2005
  11. Turbotab
    4 Feb 2009
    Do it, sounds like a good mod:)
  12. Yemerich
    Yemerich I can has PERSUADETRON?
    15 Sep 2004
    Interesting piece of tech, but...
    It's just me or this thing is ugly as hell??
  13. Whalemeister
    Whalemeister is so hot right now!
    27 Nov 2007
    It is but who's going to notice when it's stuck to the back of a TV / monitor...
  14. Paradigm Shifter
    10 May 2006
    I look at the standalone pics and it looks huge... then hands appear in the picture and it looks tiny. :hehe:
  15. Stelph
    Stelph Minimodder
    24 Dec 2007
    Trustedreview have revealed the price:
    http://www.trustedreviews.com/pcs/news/2009/04/27/Acer-Confirms-Aspire-Revo-Price---Release-Date/p1
    Personally im eyeballing the £149 version with the £50 remote as an extra and Windows 7 beta, would make an awesome HTPC with my external HD and also using a DVB-S USB hub for Freesat TV. Only issue I can see is that the atom cpu is supposed to be useless at Flash ect, so iPlayer and the other catch-up channels online wouldnt work properly, hoopefully nvidiea can fix this issue by letting the 9400 GPU step in...
  16. TTmodder
    TTmodder Hammertime
    9 Apr 2005
  17. yuusou
    yuusou Multimodder
    5 Nov 2006
    Mod it into my EeePC 901! That would be truly awesome!
  18. Anakha
    Anakha Minimodder
    6 Sep 2002
    As mentioned, throw an XBMC live distro onto this thing, couple it with an NAS/DVR (MythTV anyone?) in the cupboard/loft/cellar, and you've got yourself one truly awesome HDTV setup. In fact, 802.11n is (just about) enough to stream HDTV over, so you'd only need 2 cables (Power + HDMI). Replace the HDD with a CF-SATA adaptor and a 4GB CF card (Or a small, cheap SSD), and you've got a virtually silent HD box that can play your (ripped to HDD) Blue-Ray and HDTV without issue, using a tiny amount of power.
    In short: WANT!!!
  19. Stelph
    Stelph Minimodder
    24 Dec 2007
    F.Y.I. The basic one for £149 does come with an 8GB SSD HDD
  20. Guest-16
    Guest-16 Guest
    It'll easily fit a nix distro and XBMC - then just pull the media from the network or use the eSATA port. :)
Tags: Add Tags
