News Inside the Acer Revo
Discussion in 'Article Discussion' started by CardJoe, 27 Apr 2009.
  1. flatulatorx
    flatulatorx What's a Dremel?
    28 Apr 2009
    Anyone know what power input is? Would be really nice if this thing can be powered directly from a 12V car battery.
  2. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Its likely a 12v power brick, but a car battery doesn't give a constant enough voltage to run computer. Well not without venturing into wide input psu's but then you'd have to transplant it into the revo.
  3. flatulatorx
    28 Apr 2009
    Horror upon horrors! Does the Revo not have S/PDIF???
  4. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    nope, but what did you expect from a cheap atom/nvidia based system?
  5. flatulatorx
    28 Apr 2009
    Uhhm, dunno...didn't think something so basic was too much to ask. Based on the 1080p hype I didn't think they could/would miss the other half of the HTPC equation (ie, sound).
    You can always use a USB sound device like the cool little Turtle Beach Audio Advantage Micro to output to S/PDIF, but these types of USB devices by nature use CPU resources which the Atom has little to spare.
  6. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    True.
    I bet they make a revision of the revo after 6 months or so, adding more features.
  7. Rexxie
    Rexxie What's a Dremel?
    18 Nov 2002
    Sorry to dig this up. Was wondering if there were any "void warranty if seal removed" stickers on it? Would I void the warranty if I replaced the RAM?
  8. kaex88
    kaex88 What's a Dremel?
    10 May 2009
    Newbie question: how portable are nettops?
  9. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Nettops themselves are very portable. The problem might be the monitor, keyboard and mouse you need. ;)
  10. kinnth
    kinnth What's a Dremel?
    17 May 2009
    What would people recommend as the best remote to couple with this box?
    I dont want a mouse or a keyboard and im thinking of doing the xbmc jobby connecting to my nas?
  11. dazza76
    dazza76 What's a Dremel?
    7 Oct 2009
    I have to ask a dumb question so here it goes.
    is it possible to change the cpu or are they integrated
    appoligize for noob question
    Cheers D
  12. Anakha
    Anakha Minimodder
    6 Sep 2002
    IIRC, Atom CPUs are only available as BGA components, which means they have to be soldered onto the motherboard.
    "Integrated" would be the best answer.
  13. cheaptalk
    cheaptalk What's a Dremel?
    22 Oct 2009
    2 things: First, I got the atom 230 w/ 1gb ram, and I want to replace my windows XP with W7 32 bit....good idea or not??? Second, I want to add another gb of ram but is there a slot for that??? Just wanna be sure before I tear it apart, thanks so much!
  14. tiffinjoe
    tiffinjoe What's a Dremel?
    27 Mar 2010
    Do you think this setup will work for the revo, with the xbmc bd hack.
    http://forum.xbmc.org/showthread.php?t=67420
    esata casing
    http://www.ebuyer.com/product/198213
    liteon bd player
    http://www.amazon.co.uk/Liteon-IHOS...ftware/dp/B002BAT1GQ/ref=cm_cr_pr_product_top
    and an esata->esata cable
    http://www.amazon.co.uk/1m-eSATA-to...1?ie=UTF8&s=electronics&qid=1269689983&sr=1-1
    £70 ish
    any one had luck with any bd setup like this.
    I will probably get this in a paydays worth of time and feedback, much cheaper than the other options.
  15. tukom
    tukom What's a Dremel?
    30 Apr 2010
    While Acer Revo is an ok choice, it is facing increasing competition by other nettops and mini PCs: http://mymediaexperience.com/next-generation-of-mini-desktop-computers/
    However, what I really like about Revo is that it produces extremely good price per performance ratio. Unfortunately, I am still missing the IR receiver which I would really need as a built in feature.
Tags: Add Tags
