Intel Core 2 Duo E4300
Discussion in 'Article Discussion' started by Tim S, 1 Feb 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    and they consume less power than the cpus from AMD... i am still waiting for K8L and the new graphic card from AMD/ATI
  3. kenco_uk
    28 Nov 2003
    I can see why due to time constraints, but it's a shame you didn't run the suite of benchmarks on the E4300 when overclocked. I would imagine the numbers would be quite amazing for Intel's lowest priced C2D chip.
  4. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    Like it Tim, bit suprised that the QX6700 was bogged down in the decoding tests.
    It was nice to see that the AMD's weren't that far of the pace (mid ranged anyway) and that the EX6800 really does give you that performance increase.
    Is this the first test when you have compared so many CPU's? I don't seem to remember it cropping up lately.
  5. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    That just reaffirmed how behind the P4s were. Unless K8L surprises us, I might pick up an allendale for a cheap OC once the prices drop (have an e6300 @ stock for now). Thanks for the review.
  6. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    sweetness! all the review lack of now is the benchmark of the overclocked results!!!!!! :D
  7. samkiller42
    25 Apr 2006
    Nice one as always tim :thumb: You should put it in one of the EVGA boards you have, it will shine in there :D
    Sam
  8. mclean007
    mclean007 Officious Bystander
    22 May 2003
    I had thought the 9x multi and 2MB cache might have let it OC a bit farther than that (not that 3.15 GHz from a 1.8GHz stock chip is bad!), but still those are some impressive results from such a cheap CPU.
    Any idea how the power draw at stock and OC compare to a 6300 at similar clocks?
  9. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    Nice table of comparison for future chips at the beginning, Tim -- very helpful :)
    I think if I was buying a Core 2, I'd be waiting for the E6650. Coupled with some uber 1333MHz DDR-2 and an bit of overclocking, that'd be sweet. :D
    Lack of VT in the E4300 is a downer. I guess if you're into overclocking and multiple operating systems, it's not for you.
  10. Hugo
    Hugo Ex-TrustedReviews Staff
    25 Dec 2006
    But on the other hand how, how many people are likely to be particularly thrilled at paying extra money for a redundant feature?
  11. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    Actually, you'd be better off with the 6600 for OCing than the 6650. The key to a strong overclock is a high multiplier and low FSB...that's why the P4D 805 did so well. RAM can end up being a pretty strong limitation, so if you can get around it with a really high ram and a low initial FSB, you can clock up to the RAM and get the most raw MHz in the process.
  12. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    I never thought about it like that. Nice one :)
  13. NoMercy
    NoMercy What's a Dremel?
    23 Nov 2004
    I was pondering geting a 2nd core2 duo machine, but if I did It probably wouldn't be a E4300 just because they lack Intel VT.. guess I'm a geek though :)
  14. Jodiuh
    Jodiuh What's a Dremel?
    17 Mar 2006
    How bout running those High Res Gaming benchmarks w/ 4xAA/16xAF? I wonder how close it'd be then...
  15. Tim S
    Tim S OG
    8 Nov 2001
    I'll see what we can do about an OC comparison article :)
    We've been comparing them like this for a while and slowly built up CPUs since June.
  16. Ringold
    Ringold What's a Dremel?
    27 Jul 2006
    Me too, me too.. I'm thinking Anandtech's chip may have been a lucky draw. This has cooled the rampant enthusiasm I had for the E4300, glad you guys reviewed it :)
    Seeing a 450mhz spread between two different reviews using identical motherboards might indicate how variable our luck might be in our OCing adventures with it. I might just swallow hard and get a E6600 after all..
  17. Pointy Burdz
    Pointy Burdz What's a Dremel?
    24 Jul 2004
    That might prove to be the case, I only had a brief fling with e4300 in my Shuttle, but with +0.15 on vcore and clockgen I managed to run a few super pi 1 meg tests at 400fsb, my fans were still set at ultra quiet btw, so I'm hoping to reach 400 prime stable in my abit quad gt some time next week.
    The chip is currently sitting at default in an msi g965m matx board :sigh:
  18. GrahamC
    GrahamC What's a Dremel?
    21 Jun 2006
    Just purchased the parts for a Duo system yesterday the day before you post a review :wallbash: . As it happens I went for the 6300 over 4300 for exactly the price reasoning stated in the review. For the £6 difference I paid the extra features are handy. The 4300s price place is £25 lower. Enjoyed the review.
  19. Fiber4now
    Fiber4now Don't feed the trolls
    28 Jan 2007
    Tim, due to the fact that your review of these two cores was late to the party their was no reason for you to do a review of these two C2Ds with out the overclocked versions represented in your suite of test. The reason for this is that most other well known sites have crowned the E4300 the Value King by a large margin due to its overclock-ability. To read your review of a 1.8 GHz processor being compared to all the other higher clocked processors was very lame. We know the C2D core technology has its advantages but give me a break 1.8 GHz and a 800 MHz FSB are big disadvantages that make your out of the box comparison a joke. This review was useless on many levels, fairness was one. You wanted to show AMD was competitive in price and by making this an out of the box comparison you proved what you wanted and got to add your presumption about AMD having value in this segment of the market in your final thoughts. The readers of your review go away with a 7 score because you did not do your review correctly to justify the reason why anyone would read Bittech in the first place, which is to get inside the numbers and see what all the buzz is about. Your failure to do the work needed to overclock the E4300 after I presume you read at least one or two other articles about the E4300 and knowing what the other sites have said about the E4300 overclock-ability, shows me that you may not enjoy what you are doing any longer thus your of lack of curiosity to evaluate for yourself what the other sites where saying, which was that the E4300 overclocked was on par with the E6800 performance. Making the E4300 the best value priced CPUs in consumer history and not a 7 as you suggest.
    PS. The next time you want to use that old, time restraint excuse, make sure the buzz about the new CPU is not the exact reason that people would read about a low price core on a highend review site.
  20. Tim S
    Tim S OG
    8 Nov 2001
    Thanks for your comments. I'm sorry that you didn't enjoy the review, but I'm having trouble understanding why you've got such a chip on your shoulder.
    The fact of the matter is that Core 2 Duo E6300 chips are clocking well beyond what we achieved with our Core 2 Duo E4300 and at only £5 more in the UK, it's an infinitely better buy at this moment in time (we're a UK site with UK advertisers, so we generally don't research pricing in USD except for official pricing from Intel/AMD, as shown on the first page of the review).
    You can do the research into the E6300's overclockability for yourself, as many enthusiasts have had them in their systems for ages - here's quite a good starting point with a lot of data. Note how many of the E6300's got above 3150MHz with less than 1.5V - how much we needed to get any kind of stability at that speed with the E4300 we have here. The chip went to 2.4GHz without a voltage increase, but it wouldn't go past 3GHz with anything less than 1.5V. The CPU refused to POST at anything above 360MHz with the 9.0x multiplier but was capable of well over 400MHz with the 6.0x multiplier.
    As was stated in the review, if and when the chip comes down to around £80 including VAT next quarter, it will be one of the best value CPUs around, period. Also, if you'd read the review properly, you would realise that I stated that the E4300 was a better buy than the Athlon 64 X2 4200+ because it is more overclockable and generally faster out of the box too if you're not a heavy multitasker.
    As you can imagine, I'm struggling to understand where you're coming from on most points. I also don't understand why you're accusing me of playing a "time constraints" card on this review when:
    1) I haven't said anything like that - so please don't put words into my mouth, and
    2) I actually worked on it for longer than I'd typically spend on a CPU review. :sigh:
Tags: Add Tags
