Hardware Intel Core 2 refresh: QX6850, E6850 & E6750
Discussion in 'Article Discussion' started by Guest-16, 17 Jul 2007.
  1. Guest-16
    Guest-16 Guest
  2. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    The E6750 is looking mighty appealing to me.. though that Q6600 is kinda drawing attention to itself there as well... I suppose recommendations would be the Q6600?
  3. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Can we have (or have you done) a Q6600 centered article, OCing etc, its what most of us will be buying :) Thanks
  4. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    yeah im getting a q6600 if i can bump the frequency to 3.3 ish id be happy and looking at the G0 i think this is very possible
    i would like to get a x38 tho so i can run dual 2900's (dependant on crysis performance) anyone know when this is due out
  5. Guest-16
    Guest-16 Guest
    We don't have a Q6600 retail and I wouldn't like to use an ES because it's potentially a "golden" result. It also depends on motherboards etc: for example if you buy an Abit IP35 Pro or DFI ICFX3200T2R/G you get GTLReference voltage adjustments which specifically helps with quad core overclocking.
    With an IP35 Pro you should easily get it to 333-400FSB. Abit has got quad cores to 500 in its labs.
  6. adidas
    adidas What's a Dremel?
    8 Jun 2005
    Pricing is weird
    First, thank you for this fantastic article - as usual I might add :D
    The only 'problem' (if you could call it that) is the pricing - I'm not understanding the Q6600 at £160. Reason is, scan has it priced at £234.95 exc VAT today. Are you saying that comes July 22, I'll find that the price has been slashed by 75 quids? Sounds like a lot.
  7. Bladestorm
    Bladestorm What's a Dremel?
    14 Dec 2005
    It might just mean there isn't a lot of stock in the channels at the moment, so the vendors are pricing it higher because they know it will sell out anyway.
  8. DarkLord7854
    22 Jun 2005
    Any ideas what it'll look like with a 680i chipset?
  9. Tim S
    Tim S OG
    8 Nov 2001
    I'll see what I can do ;)
  10. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    mighty tempting..... lets see the response from AMD's side.
  11. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
  12. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    Very nice review... I would have liked to see how the slowest 1333mhz bus core 2 duo chip survived. Definitely helped me make up my mind though between AMD and Intel.
  13. Tim S
    Tim S OG
    8 Nov 2001
    Thanks, I'm trying to get one of those too! :thumb:
  14. KMS-oul
    KMS-oul You think you know me.
    1 Aug 2002
    Great stuff. Looks like the Q6600 is the best choice for those wanting performance at a budget. I look forward to bit doing an article on that thing :p. Hopefully it overclocks well. Ill be happy if I can get 300mhz OC out of it on air.
  15. kickarse
    6 Oct 2004
    Does anyone know the ETA for retail supply? Did I miss that in the article?
    Yeah the slowest 1333mhz bus chip (quad or duo) will be the one I upgrade to/overlock with. I want the Core 2 Duo E6540 _without_ TXT.
  16. Renoir
    Renoir What's a Dremel?
    19 Jul 2006
    In addition to the ways of making use of multi-core cpus mentioned in the article (multi-tasking and multithreaded apps) a lot of apps also have the option of running 2 instances. E.g. If you had say 100 audio files to convert to mp3s you could run 2 instances of say dbpoweramp and have each one convert 50 tracks. This reasoning would work for video encoding too and would extend to quad core. Merely wanted to point out that with a bit of planning there are less obvious ways of taking advantage of multi-core cpus :thumb:
  17. Nature
    Nature Minimodder
    21 Nov 2005
    The good: Yes, all is fantastic in the land of compy-coms right now, 2 gig's of ddr2 for 100 bucks, a quad core processor for chip like prices, vid cards, power supplies, motherboards, and hdd's are a bit pricey though. All in all this is fantabulous for us who are still using pentium 3's cause we can't handle our estates (wo).
    The bad: people like me think they should be talking about issues in which others could articulate and sum up much "more better".
    The ugly: HTPC cases still blow marbles, and mobile gaming is still slackin'.
    I'd like to see the 8800m power the Wii :D
  18. Tim S
    Tim S OG
    8 Nov 2001
    ETA should be next week on the 22nd (I'm sorry if I didn't state that explicitly) :)
  19. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I really want a E6750 or a Q6600 for my next CPU
  20. Tim S
    Tim S OG
    8 Nov 2001
    Oh, so you didn't bother reading the page that is dedicated to Supreme Commander performance?
    Crysis is the first of the games coming out in the future... SupCom is from the past since it's already out! :duh:
Tags: Add Tags
