News Intel Turbo Memory for Desktops?
Discussion in 'Article Discussion' started by Tim S, 7 Jun 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    I dunno. With larger memory sizes getting common (4GB anyone?), hybrid drives and readyboost it seems a bit pointless for desktops.
    I'd probably buy one though, or pay more money for it to be included in the motherboard.
  3. Paradigm Shifter
    10 May 2006
    Yes. It also makes me wonder what stuff they might have put in there that has more sinister possibilities...
    ...but hey, maybe I'm just being paranoid. :hehe:
  4. mclean007
    mclean007 Officious Bystander
    22 May 2003
    ^^ how your post appears on a machine powered by a 3 series Intel board.
  5. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    easter eggs are cool as long as they are good for you.
  6. Guest-16
    Guest-16 Guest
    I actually have a photo of that text appearing on a stand.
  7. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I don't think anyone will care in a year
  8. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    Remember, just because they arnet visible doesnt mean they're not after YOU :hehe:
  9. ./^\.Ace./^\.
    ./^\.Ace./^\. What's a Dremel?
    7 Jun 2007
    I agree, I wouldn't use it :yawn: if I needed more memory like that then i would get a board that holds more RAM :yawn:
  10. crash32953295@msn.
    crash32953295@msn. What's a Dremel?
    2 Aug 2004
    Well it would mean there is a use for that slot
  11. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    Readyboost as long as you have more then 2gb thay shown no inprovement as superfetch wold of all ready loaded it up into the system ram cache
    useing an USB stick in my pc to use readyboost slows my games down makes them stutter more but i am guessing thats the USB interface doing that on an PCI-E interface it supports 256MB Each way
    if buying an vista pc does not matter what specs it has as long it has 2gb of ram (dual core cpu should be min tho)
    if playing games on Vista get at least 3gb ram {so get an 4gb Kit 2x2GB, even if your useing vista 32 bit (it only see 3.2gb out of the 4gb but thats not an problem) or thinking of getting vista 64 later on} or the games will suffer on High detail levels {BF2142 for e.g. {need to get my other 2x1gb replaced pc does not post with them in}
    i find games run not that well on vista any way vista looks nice superfetch works as intended DX10 hmm only Company of heros (1.7v) has DX10 support (looks very cool tho)
  12. ./^\.Ace./^\.
    7 Jun 2007
    Well if you get the new Asus PCIe sound card then you could put it there insted :D If you really need fast memory access then you could use the iRAM thing, that could work almost the same as Intel's Turbo Memory thing :D
Tags: Add Tags
