Hardware Intel's Santa Rosa mobile platform
Discussion in 'Article Discussion' started by Tim S, 9 May 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    Sounds good to me :)
    Wonder how well it could handle Ultimate though
  3. Robotrix
    Robotrix What's a Dremel?
    11 Mar 2007
    There's no performance difference with running the Ultimate version of Vista compared to other versions... LOL.
  4. 1e8o
    1e8o What's a Dremel?
    13 Oct 2005
    Interesting...looking for an new notebook...
  5. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    8600GT? I wonder how this stacks up against the current top of the mobile gfx leaderboard the 7950GTX.
  6. DarkLord7854
    22 Jun 2005
    It says it can run Premium, doesn't say anything about the others, so how can you be sure?
  7. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Might have to hold off a laptop upgrade for a little bit then! Do you have any rough figures for battery life at all? If possible comparaisons to similarly specced "old" merom systems
  8. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Ultimate is only running slightly more services, Aero et al is exactly the same as it is on premium.
  9. GamingHobo
    GamingHobo What's a Dremel?
    20 Apr 2007
    That's pretty difficult atm because by all accounts Vista does have some effect on battery performance, so any testing would have to be done on Vista and MobileMark - the benchmark for battery testing - doesn't currently work on Vista.
  10. Highland3r
    25 Jul 2003
    Just after a rough flavour, doesnt have to be anything scientific. Just a "bit better/loads better/crap" would do fine :)
  11. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    Interesting stuff :thumb:
    I'm just hoping they don't build Robson / Turbo Memory / ReadyBoost directly on to the main board. I'd be willing to accept a little bit bigger laptop if it means this is put on modules that can be removed, replaced, or upgraded - if it's soldered onto the board I'm not interested
  12. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    i hope it is all modular. and i hope some of this technology comes to desktops :D.
  13. Saivert
    Saivert Minimodder
    26 Mar 2005
    As for desktops you already got iRAM solution for very speedy harddrives, and you can put USB devices internally by doing some modding (e.g. hook a USB thumb drive directly to the pin headers on motherboard).
    ExpressCard solution is also usable for ReadyBoost. And according to TrustedReviews you can look forward to 4GB, 8GB & 16GB ExpressCard SSDs From Lexar.
  14. Tim S
    Tim S OG
    8 Nov 2001
    Bearlake will come with Robson technology too, afaik.
Tags: Add Tags
