Hardware Investigating SATA 6Gbps Performance
Discussion in 'Article Discussion' started by Tim S, 16 Nov 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. kenco_uk
    28 Nov 2003
    For a professional e-publication, the amount of spelling and grammatical errors that appear frequently throughout articles on bit-tech is quite frankly shocking. Please either hire a copy editor or purchase/code some software which does a better job than a second pair of eyes skim-reading it before it's published. Harsh, perhaps, but it requires bringing to task imo.
  3. stonedsurd
    11 Mar 2009
    So basically not worth it at the moment. Nice article though :)
  4. Autti
    Autti What's a Dremel?
    29 Oct 2009
    Hmm seems Intel and AMD will be the limiting factors for drive speed now, P55 with only 16 PCI G2 lanes doesn't look so good now considering if you run a SATA6Gb/s SSD it drops it to 8x for your GFX card, so bye bye SLI and CF.
  5. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    If you're splashing the cash on SATA6 SSD, I doubt you'll be running anything based on mainstream P55 anyways.
  6. Guest-16
    Guest-16 Guest
    If we did that, where would the fun be for YOU picking out the slight grammatical errors? :hehe::hehe:
  7. dec
    dec [blank space]
    10 Jan 2009
    isnt pci express 3.0 due out in a year or so? better these are released before the SSD's overfill the current bandwidth
  8. stonedsurd
    11 Mar 2009
    Agreed :p
    Let the grammar nazi's have their fun, but please at least edit the mistakes that are pointed out. Quite often, they go unedited even after they are quoted in the comment threads.
  9. kgwagner
    kgwagner What's a Dremel?
    20 Jan 2005
    The title to this piece should have been "WD vs. Seagate 2GB Drive Performance", since that's what the entire article was about. Only in the last paragraph do you finally mention that the 6Gbps interface isn't bringing anything to the party (yet), which I suspect everybody already knows since there aren't any drives going hungry on the 3Gbps interface.
  10. Guest-16
    Guest-16 Guest
    They are all changed at some point during the day/48hrs.
    That's not it at all - we compared SATA 6Gbps to SATA 3Gbps, on two separate SATA connections on two separate motherboards that have completely different ways of using the Marvell chipsets. The graphs show all this data.
    I've also amended the article to note the Asus board uses the 88SE9123, not 28: it does not feature RAID.
  11. impar
    impar Minimodder
    24 Nov 2006
    Greetings!
    Was expecting to see SSDs as the drives, not 7.200 RPMers...
    WD > Seagate ?
  12. Guest-16
    Guest-16 Guest
    There's no such thing as a SATA 6Gbps SSD until next year, otherwise I would have used one also.
  13. wyx087
    wyx087 Multimodder
    15 Aug 2007
    nice to see Asus kept their useless plastic on top of the south bridge.
    so basic conclusion is SATA 6Gbps is not needed until ultra-fast SSD's come around.
  14. impar
    impar Minimodder
    24 Nov 2006
    Greetings!
    Dont SATA 3Gbps SSDs benefit anything from SATA 6Gbps?
  15. Guest-16
    Guest-16 Guest
    I tested with an Intel G2 160GB, and no, there's no difference at all. I just didn't include the results because they didn't say much and the graphs are already very data-heavy.
  16. impar
    impar Minimodder
    24 Nov 2006
    Greetings!
    Ok, thanks.
  17. Guest-16
    Guest-16 Guest
    No problem! :) Thanks for the question (I had already anticipated the answer to for a change) :hehe:
  18. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    Althought it is unprofessional, I do agree it's fun pointing out the mistakes. I'd rather have someone with a passion for what they are talking about make a few mistakes than a grammar expert write a load of rubbish!
    This sentence is best with a Mario accent, "...although as a premium, performance disk drive you'll pay a through the nose..." ;)
    And this is a bit muddled: If the BIOS is has the setting of "Turbo SATA 3.0"
    No need for the 'of': and we still have the same eight of SATA ports as the Gigabyte board
  19. BohleyK
    BohleyK Cinnamon Life FTW
    9 Oct 2009
    For a professional e-publication, the amount of spelling and grammatical errors that appear frequently throughout articles on bit-tech is shocking. Please either hire a copy editor or purchase/code some software which does a better job than a second pair of eyes skim-reading the review before it is published. Trolling, but it requires bringing to task.
    I fixed your grammatical fail!
  20. tseax
    tseax < >
    5 Mar 2009
    Useful article - thanks a bunch Richard!
Tags: Add Tags
