News iPods screw with pacemakers
Discussion in 'Article Discussion' started by Da Dego, 11 May 2007.
  1. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
  2. TheEclypse
    TheEclypse What's a Dremel?
    11 Aug 2003
    Surely whatever it is in an iPod thats causing problems will be in many other electronic devices as well?
  3. robbybertu15
    robbybertu15 <b>needs a job</b>
    28 Feb 2005
    That what I was thinking. It seems very unlikely that this is an ipod specific issue.
  4. bilbothebaggins
    bilbothebaggins What's a Dremel?
    1 Sep 2006
    Makes one wonder what the |FCC| or the (CE) emblem is for ... :duh:
  5. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    No discuss link at top of story
    How does this apply to the concerns about Wi-Fi discussed in this thread: (link)
  6. yodasarmpit
    yodasarmpit No longer the other Brett.
    27 May 2002
    Like others have said pretty much any electrical item will produce similar or greater EMI, god forbid granddad sits in front of the telly.
    So the real issue is that the pacemakers didn't have effective EM shielding.
  7. pendragon
    pendragon I pickle they
    14 May 2004
    yea, as much as I dislike Apple and wouldn't mind seeing the Ipod fail, I agree its most likley what you said.
  8. Zurechial
    Zurechial Elitist
    21 Mar 2007
    It's worth noting that the uneducated masses, due to Apple's viral marketing, will often refer to all MP3 players in general as iPods, whether or not they actually are Apple iPods, just like many people colloquially refer to vacuum cleaners as Hoovers in some countries.
    The article referenced here doesn't state clearly whether the test was done specifically with Apple iPods, or with a range of MP3 players being referred to colloquially as iPods.
    Either way, it's safe to assume that any MP3 player has the potential to cause this problem anyway, but clarification could be useful..
  9. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    i would like to know how that happens.....
  10. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    Man... No doubt the kid got an 'A' for the project... Crazy to see that something keeping someone alive can be screwed up so easily...
  11. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    well that would really suck if i had a pacemakers
  12. scarecrow
    scarecrow What's a Dremel?
    4 Mar 2006
    with the em shielding I am no expert but I don't think its possible due to a pacemaker is reading the very faint electrical signal the body produces when the heart compresses. You can't really em shield that without causing the pacemaker to no function I think its more a problem of that the electrical device is giving off to much interference but what can you do ...
  13. Guest-23315
    Guest-23315 Guest
    Yeah, my grandfather has a pacemaker and after some discussions with him (he used to be a Physics professor) he always wondered about EMI, but as said above, the charge pumped out is so small and the machine so simple that EMI should do effectivly nothing.
    I would however like to see this being done with various other MP3 players to make sure that there isn't an even larger problem going on out there.
  14. CoolFox
    CoolFox What's a Dremel?
    8 Feb 2006
    I knew a guy that had is pacemaker disputed by that hand held device that the UPS driver hands you to get your signature, but that thing is like a cell phone.
    Anyway, is the EMI from an iPod really that strong? Is it all the signal processing circuitry or is it the motor for the hard drive in the older and Video iPods that throws off the most EM radiation?
  15. 330td
    330td Minimodder
    12 Aug 2004
    I think so. What about a mobile phone ? Any one tested :naughty:
Tags: Add Tags
