Hardware Is More Memory Better?
Discussion in 'Article Discussion' started by Guest-16, 8 Jul 2008.
  1. supremelaw
    supremelaw What's a Dremel?
    10 Jul 2008
  2. supremelaw
    10 Jul 2008
  3. supremelaw
    10 Jul 2008
  4. woodshop
    woodshop UnSeenly
    14 Oct 2003
  5. The boy 4rm oz
    10 Apr 2008
    Nice break down guys. Looks like I'm set with 4x1GB on Vista Home Premium 64bit SP1.
  6. kazekami
    kazekami What's a Dremel?
    10 Jul 2008
    > As you may or may not know, 32-bit operating systems are limited to addressing a maximum memory size of 4,294,967,296 bytes, or "4GB" in more normal terms
    Let's just say "32-bit operating systems from Microsoft", Linux (and OS X IIRC) can address more than 4Gb in 32-bit version
    Thanks !
  7. lankyn
    lankyn What's a Dremel?
    10 Jul 2008
    Annoyed that 4x1Gb was dropped from most of the benchmarks - I'd have thought most people would have that set-up (or like me, considering it). I'm still considering 'splashing out' for another 2x1Gb Geil DDR2 for my P5W DH (£35), but has anyone experience with four sticks on this board??
  8. tuteja1986
    tuteja1986 What's a Dremel?
    25 Sep 2005
    well i had to upgrade to 4GB because stalker was using up 99% of my ram :( .
    My OS uses 600MB
    1920x1200 8xAA , every setting high :!
    all together when playing stalker : 2150MB.
    So really all you need is a 3GB : )
  9. cjmUK
    cjmUK Old git.
    9 Feb 2004
    Don't forget... Whatever you need for your OS + most demanding game/app is the bare minimum. You need extra RAM for caching - especially in Vista with SuperFetch. Vista x64 will benefit from as much RAM as you can throw at it. So if you need 2GB+ for STALKER, 4GB is the minimum you should really be aiming for...
  10. ComputerKing
    8 Sep 2006
    Hey I was wondering. You said if you have 4GB ram and 512mb VGA card you get 3.5GB at the end. But what If I have Crossfire 512mb cards ? that will make me get 3GB at the end same the 1GB cards or what ?
  11. cjmUK
    cjmUK Old git.
    9 Feb 2004
    In effect, yes.
    The cards don't actually use RAM, but the do use up some memory addresses, of which there is 4GB worth...
  12. ComputerKing
    8 Sep 2006
    yup I know that, But my point is crossfire setup of 2 X 512MB cards will make you End with 3GB of ram not 3.5GB
    So that is right or not ?
  13. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    yes, that is right.
  14. wyx087
    wyx087 Multimodder
    15 Aug 2007
    he just answered your question: Windows 32bit can only address 4GB of memory, no matter what kind.
    Crossfire gets you 2x 512MB, and they must be addressed separately, so you'll only get 3GB of RAM left, not counting other hardware.
  15. ComputerKing
    8 Sep 2006
    I didn't understand him clearly, Sorry. And yes I know that any 32BIT OS can see 4GB memory only.
    The point was in CF thing. But now I got it. Thanks A lot. :clap:
    again cjmUK sorry for misunderstanding
  16. DougEdey
    5 Jul 2005
    64 bit doesn't suffer from that issue does it? There's far more memory addresses so it'll be fine right?
  17. cjmUK
    cjmUK Old git.
    9 Feb 2004
    Yes... under 32 bit OSs, you machine can address 2^32 (4GB) individual memory locations of any kind (RAM/GPU/etc) so the more 'etc's you have the less of your 4GB RAM you can address.
    Under 64-bit, you have 2^64 (18 exabytes) memory addresses, so using your 4GB RAM leaves 18EB - 4GB = er... well, a lot of free memory addresses.
  18. DougEdey
    5 Jul 2005
    That's what I thought, I just wanted to check my brain wasn't dead.
  19. ComputerKing
    8 Sep 2006
  20. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    Tasty card. But no that doesn't suck. Just get with the times and install a 64bit os!
Tags: Add Tags
