Motherboards ITX Anonymous Club
Discussion in 'Hardware' started by Arboreal, 11 Jun 2016.
  1. nimbu
    nimbu Multimodder
    28 Nov 2002
    I don't believe that that fits on the v1 Dan case :(. Might be good for the ncase though.
    As for noctua's obsession with brown, it's kinda grown on me over the years,. Though what I would give to have modern versions for my old papst fans
  2. David
    7 Apr 2009
    So, I was looking at mATX boards that might fit in the Ncase M1.
    The Asus ROG Gene XI thingy Flex-ATX board will (sort of) fit, if you bugger about with the PSU mount, but it's about £300.
    I ended up trawling through the product pages of all the big manufacturers looking for a 226mm wide boards with three slots, and found this:
    Just about everything else had a single 16x and two 1x slots, but this has a 4x slot :D
    It's far from perfect - It doesn't support OCing and has VGA and DVI, a single M.2 and no USB C, but it has 6 SATA ports, all of which are available when running a PCIE m.2 drive, and a SATA m.2 will still leave you with 5 SATA ports. It also has four RAM slots. Less than £70 shipped.
    TBH, other than a few half arsed benchmark runs, I haven't really bothered OCing my CPU, so I don't really care.
    Regardless, it fits! I did mod my ATX PSU bracket, so I have a fair bit of clearance, but using the vanilla bracket and a SFX to ATX adapter, it'd still fit.
    bawjaws, Arboreal and adidan like this.
  3. adidan
    25 Mar 2009
    @David if something fits with a hammer, I class that as a success.
    If something fits without a hammer, well, that's the stuff of legends.
    MLyons likes this.
  4. Goatee
    Goatee Multimodder
    19 Apr 2015
    My latest build. Will eventually become my daily driver, replacing a S4M.
    Vault-Tec, Arboreal, bawjaws and 3 others like this.
  5. Arboreal
    21 Jan 2011
    Oh hello (insert this week's manufacturer name) T1! :cool:
    Looking very neat and well crammed in, congrats on getting the test build done.
    No pressure, but you're the sole UK representative for the moment...
    Goatee likes this.
  6. David
    7 Apr 2009
    It's pretty tight floor to ceiling. Seriously, another 1mm and it wouldn't fit.
    Arboreal likes this.
  7. adidan
    25 Mar 2009
    In a thousand years they'll base a religion on this moment.
  8. Arboreal
    21 Jan 2011
    Great spot there @David, lovely looking board to cram into your M1.
    All I found on that front was the Asrock H310CM-HDV/M2, which is somewhat less capable. That 4x slot makes quite a difference. I do have a dual M.2 4x card in stock, that takes an NVME and a SATA, making 3 if needs be.
    I don't have an ATX bracket for my M1, so this could well be a non starter. Keep in touch on this one.
    For the record, this month's money is going on BRIGHT LED strobes for the Mavic Pro
  9. Goatee
    Goatee Multimodder
    19 Apr 2015
    I know, I'm waiting on some fittings, then I might go full hard line if I can find my heat-gun (and hard tubing).
    Spec's if your interested:
    PC components:
    I9-9900KF
    Aorus Z390 I AORUS PRO WIFI
    32GB of Crucial Ballistix Sport BLS16G4D30CEST 3000 MHz
    EVGA RTX 2080
    Samsung 1TB SM961
    Corsair SF450 Gold
    J-Hack M2427 cables
    Cooling Components:
    Rad - Coolworld 240 - 24mm thick @ 12FPI
    CPU block - Apogee Drive II
    GPU block - Hydro X Series XG7 RGB 20-SERIES GPU Water Block
    Pump - EK Water Blocks EK-DDC 3.2 PWM
    Fans - 1 x F12x25 PWM, 1 x A12x15 PWM
  10. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Tasty. What are you planning to use those extra PCI-E slots for? I guess if you're using a GPU then you'll only be able to access the third slot?
  11. David
    7 Apr 2009
    Way to cram it all in! Very nice.
    Won't the heatsink for the Apogee Drive fit? It looks a lot better than the arse-end of a DDC :)
    Yeah, the third slot is now home to a 10GbE NIC. I did have it running off a nvme>pcie adapter, using the 2nd m.2 on the back of my ITX board, but it was a wee bit flaky and would occasionally drop the connection; requiring a reboot to pick it up again.
    BeauchN, Arboreal and Goatee like this.
  12. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    @David , that is pretty sweet! Shows the genius of the NCase design to have that third expansion slot, whether it's for extra room for fans or for an additional card. And nice to see a board that has those extra PCI-E slots too.
    Arboreal and David like this.
  13. Arboreal
    21 Jan 2011
    Your M1 looks a lot more spacious with the PSU moved to the front; you can see daylight between the board and PSU!
    Fine looking rig there. My Noctua rear fan is on the case, maybe it'd be happier on the rear of the cooler...
    I am still interested in the J-Hack M2427 SF600 PSU mod that removes 17 ATX PSU cables and runs 12v over remaining 7 to the motherboard via a Pico PSU type adaptor.
    That'd save space and allow it to breathe better.
    @ Bawjaws, the 3 slot strategy was an inspired move by Necere. I am thinking of putting a PCI slot mounted 2.5 drive caddy in mine, but at the moment, the 1TB HDD backup drive behind the front panel in the ODD space works a treat!
  14. Goatee
    Goatee Multimodder
    19 Apr 2015
    I have one and its a cracking little add-on. Saves a lot of space in my T1.
  15. David
    7 Apr 2009
    Yeah, the 24 pin on the SF series is a cumbersome pig of cable. I can see the appeal.
  16. BeauchN
    BeauchN Multimodder
    5 Apr 2011
    Well, here’s what my M1 looks like with everything crammed in. Now just need to get the RAM to play nicely, which is proving a headache, each stick passes memtest on its own on XMP (3600 CL16), but put both in and it doesn’t like it. Oh well, something to keep me occupied...
    Arboreal, Goatee, David and 1 other person like this.
  17. David
    7 Apr 2009
    One of us!
    One of US!
    ONE OF US!!!
    Arboreal, Goatee and BeauchN like this.
  18. Goatee
    Goatee Multimodder
    19 Apr 2015
    BeauchN and Arboreal like this.
  19. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    crammed? Could fit a bus in there
  20. BeauchN
    BeauchN Multimodder
    5 Apr 2011
    I know, I was being slightly melodramatic :) Though that means space for a thick-rad AIO to cool a 4950X later on - should one ever exist and I can afford/justify it
    The RAM is happy in dual channel at at a slightly lower speed, though that doesn’t seem to affect gaming so I’m not really worried.
