Motherboards ITX Anonymous Club
Discussion in 'Hardware' started by Arboreal, 11 Jun 2016.
  1. adidan
    25 Mar 2009
    At least @Goatee wasn't asking you mate, that'd be a whole different kettle of small form factor pics. :p
    Goatee and Arboreal like this.
  2. adidan
    25 Mar 2009
    Nice although i think you could have cut a smidge more off the cable tie excess there mate. :happy:
    Moar pics pls. Not seen colour psu cables like that for a while.
  3. Arboreal
    21 Jan 2011
    Not guilty your honour, that was on it when I bought it. It really has to come off so that I can pass the 24 wires through the (almost non existent...) cable cutout flat rather than bunched
    Them cableses, who needs RGB lighting? I was hoping to wrap them, but there's no room. Maybe black paint / marker / vinyl dye... Sub heading - Adventures in Flex ATX PSU land. My SFX PSU looks silly big by comparison!
    All in good time for pics, I need to take it all apart tomorrow and start again from scratch, as I need it in bits to route fan cables and the PCIe riser and a power switch if there's room...
    The case itself is work of art / nightmare, as it's 222 x 181 x 111 mm!
    David, Goatee and adidan like this.
  4. adidan
    25 Mar 2009
    Tease.
    Blimey that's a dinky old case. Sounds small enough that you could lose it if you sat on it by mistake.
    Arboreal likes this.
  5. Goatee
    Goatee Multimodder
    19 Apr 2015
    If you can lose 4.4L up there, you should maybe take up a new career as a contraband smuggler....
    David, adidan and Arboreal like this.
  6. adidan
    25 Mar 2009
    Don't be ridiculous - have you seen the travel ban list?
    David, Arboreal and Goatee like this.
  7. Goatee
    Goatee Multimodder
    19 Apr 2015
    Well if your struggling for space due to having to mask it up first, then you could try carrying my travel case in the old prison wallet. Its only 4L (sorry @Arboreal) so will be banging around in there. :D
  8. David
    7 Apr 2009
    Is that a Velka?
  9. jsbombjack
    jsbombjack Minimodder
    14 Mar 2015
    I forgot pc building was so hard on the knees...
    Finally got my NR200P built. Managed to get the cables semi-routed, but damn those evga sfx cables are solid and a pain in the arse to get tidy. Definitely asking santa for a Silverstone with some short cables...
    Initial feedback is good, though I can see where the money was saved. The only real issue I have is the really long usb 3 cable is silly. There must be a better way.
    I did manage to get 2x140mm fans in the bottom between the floor and the gpu with an adapter, but there not enough space even with a genuine 2 slot card to run them as they foul the gpu fans (at least they did with my Gigabyte Windforce 2080ti). Maybe if I sanded the adapters a bit I would get the clearance, but for now I'll slum it with 120mm fans
    Temps look OK (55c load on the cpu, 75c load on the gpu) and noise is good, but then again all 6 fans are plugged into a commander pro so I can tune them tomorrow if I need to. The extra airflow compared to the Nano S is immediately evident.
    All in all, I like it a lot. Definitely smaller than the Define Nano S I had (well still do) and bar the build and cabling fun, it's a good case to work with and very good value all in.
    Full specs are
    i7 9700k
    Corsair 240mm aio (side mounted)
    Gigabyte Aorus Z390
    Evga 650w (less said about the cables the better)
    Gigabyte 2080ti Windforce (non-OC horizontal mount)
    2x nvme
    2x SSD
    6x 120mm fans
    Commander Pro
    adidan, Goatee and Arboreal like this.
  10. Goatee
    Goatee Multimodder
    19 Apr 2015
    Is a ZS-A4DC - Its full aluminium, shrunk Chinese dan case clone (hence the A4 in the name) that supports an LP gpu (I have a GDDR6 1650 in there) along with a flex PSU.
    Here is a gallery of the case from someone else: https://imgur.com/r/sffpc/d0kfhsM
    adidan likes this.
  11. Goatee
    Goatee Multimodder
    19 Apr 2015
    Got some pictures?
  12. adidan
    25 Mar 2009
    That looks like not much bigger than an ATX PSU.
    Hm, a PC in a PSU.... * Ponders *
  13. Arboreal
    21 Jan 2011
    I Woz robbed! I wonder if he’s used the old 4L ‘internal dimensions’ trick...
    The 1050Ti is running with an 80mm Redux fan jammed between the heat sink and side panel, with 2 fan screws locating it in the top heat sink slot!
    I was hoping to fold with it quietly in the corner, but the 40mm PSU fan says otherwise. Without the 1050Ti loaded up it’s quiet. The poor Flex PSU has 20mm or so of breathing room.
    Maybe it will need a non solid front panel with 2 92mm thin Noctuas running slowly on it. That could be somewhere around v2 ;)
  14. Arboreal
    21 Jan 2011
    it’s been done at least twice on SFFN...
    adidan likes this.
  15. Goatee
    Goatee Multimodder
    19 Apr 2015
    What FLEX PSU are you using?
    I'm using one of these and its silent at around 140W
    https://www.ebay.co.uk/itm/Seasonic...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
  16. jsbombjack
    14 Mar 2015
    Hopefully this works.
    Terrible lighting, and black on black doesn't help, but it gets the point across. Not going to do a top down shot as you wouldn't be able to see much anyway
  17. adidan
    25 Mar 2009
    Oh I can imagine, will have to have a goosey over there too.
  18. Arboreal
    21 Jan 2011
    Do have a look, it's the other community I like for PC building and mods. There are a number of us from here on there too!
    I did look at the Seasonic*, but as advised that the FSP 270W was better... I bought this one as some of the others on the bay were only 20 pin.
    *Ha, I bought my ITX setup from the place you linked to, and was tempted to get that Seasonic for a while.
    The case is obvs a sandwich design, would it be worth making the 80mm fan on the GPU and extractor to get the heat out?
    After I've done some manual labour in the garden**, I'll be in to document the MT4S case build.
    **The garden office has been put back again. 7th of Sept now, a month late. SWMBO isn't happy about it.
    The base is down, but needs more air clearance under the frame, and maybe a small shingle soakaway.
  19. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    David likes this.
  20. Arboreal
    21 Jan 2011
    Thanks @meandmymouth for posting about the ML10.
    Nice job you did there with the USB3. Usually they're way too long and have a real fight to find places to lose the extra thick and unyielding cable.
    Do you have some more general pics?
