Motherboards ITX Anonymous Club
Discussion in 'Hardware' started by Arboreal, 11 Jun 2016.
  1. Goatee
    Goatee Multimodder
    19 Apr 2015
    To be fair, no-one needs a £300 pc case!
  2. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    BTW, looks like the Meshlicious should be coming up on Amazon relatively soon.
  3. el2k
    el2k Modder
    18 Jan 2010
    it's up for pre order on newegg, when is the UK pre order coming...?
  4. Omnislip
    Omnislip Minimodder
    31 May 2011
    Do we have any custom PSU cable gurus in the forum?
    I was thinking of getting some unsleeved ones from pslate - the stacked SATA connector seems too good to miss out on. Is there any place with better value or service to go for?
  5. Ending Credits
    4 Jan 2008
    Two new SFF cases from Lian-Li
    Dan A4-H20
    Q58
    kim and Arboreal like this.
  6. Goatee
    Goatee Multimodder
    19 Apr 2015
    The 58 is a good looking case. I like the split panel types.
  7. Arboreal
    21 Jan 2011
    Good spot there thanks @Ending Credits!
    No mention of the A4H20 on the Dan Case pages on SFFN, he was keeping pretty quiet about this release.
    Looks a bit of a one trick pony (as per Ali's assessment), but if you need a rad and an affordable case, it opens up your options.
    Q58 is pretty ingenious, some clever features. That accessible rear fan hub is a nice touch.
    The 2 tone finish does seem a bit derivative compared to the T1, I await to be convinced about the glass/mesh split. It would be good tohave the option of swapping either sort for the other.
    i.e. both glass or both mesh; or even mesh on top, glass below.
  8. Goatee
    Goatee Multimodder
    19 Apr 2015
    My first thought is of using some solenoids to open the mesh when fan speed is high, then closing the mesh at lower fan speeds... Cause reasons maybe.
    Arboreal likes this.
  9. David
    7 Apr 2009
    I really like the Q58 - some brilliant features there, but I'm not sold on the glass panel.
    I also think we'll find the price is about as realistic as current GPU MSRPs.
  10. Omnislip
    Omnislip Minimodder
    31 May 2011
    I couldn't believe the A4 H2O was coming in at $120. Dondan has put a picture of a potential revision to the original design that has (*gasp*) external screws. Might have just been a prototype, but surely there are quite a few corners that Lian Li will have to cut to hit that pricepoint?
  11. Ending Credits
    4 Jan 2008
    Yeah, as looks go it's not as good as the A4, but then it's a (hopefully widely available) 240mm radiator compatible case at just over 10l, which is impressive enough in itself.
    EDIT: I actually quite like the revision, although the screws aren't great. Might be a lot of people end up doing a magnet swap?
  12. Parge
    16 Jul 2010
    Any recommendations for readily available ITX cases?
    Requirement: watercooling support for CPU (120mm, as I've just got a 95w i9 9900)
    Requirement: fits SFX PSUs
    Requirement: fits my GPU - a EVGA GTX 1080ti AC2 with the following dimensions
    • Height: 4.66in - 118.48mm
    • Length: 10.6in - 269.2mm
    Edit: looking at Coolermaster NR200 and Lian Li TU150
  13. David
    7 Apr 2009
    NR200?
  14. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Both are great cases. We've done a review of the TU150 and I have a review of the NR200P coming up soon
  15. Parge
    16 Jul 2010
    Nice! I'll look out for it and go and read the lian li review now.
    The lian li, I expect, has a more premium finish, but the cooler master seems better from a functional perspective.
  16. Arboreal
    21 Jan 2011
    From what I've seen, the TU150 is no easier to build in despite being 20%+ bigger.
    Unless you need the handle*, it takes up space and complicates the build process.
    CM seem to have hit a sweet spot with the NR200. It's small, flexible, well made and not expensive compared to the sub 20L boutique cases out there.
    *I'm a sucker for handles, but it being twice the volume of an M1 is offputting.
  17. el2k
    el2k Modder
    18 Jan 2010
    You could wait for the SSUPD Meshalicious?
  18. Arboreal
    21 Jan 2011
    Good thinking that man! Not sure how soon it's due, but soon nevertheless
  19. Parge
    16 Jul 2010
    Yeah, to be honest, love the vertical form factor, but who knows when it'll be available!
  20. Goatee
    Goatee Multimodder
    19 Apr 2015
    I have a prototype rcc-big1 that is sat currently unused, if that would float your boat?
    https://revoccases.com/work/rcc-big1/
    Its a prototype (so has a couple of niggles)
