Motherboards ITX Anonymous Club
Discussion in 'Hardware' started by Arboreal, 11 Jun 2016.
  1. Vault-Tec
    30 Aug 2015
    Byron C likes this.
  2. David
    7 Apr 2009
    Well, It's not pretty but it will definitely work:
    Just using an old donor board, but it looks like everything lines up. I mean anything with high-stacked IO will interfere with the fan, and I did have to remove the two fan guide rails by drilling out the not-rivets.
    In case anyone is interested, the measurement from the bottom of the chassis to the IO cut-out is ~18mm and ~4.5mm from the left hand side. I had to shave a couple of mm off the upright separating the the PCI slots.
    **Note: These measurements were taken AFTER removing the plastic bottom and side panels.
    wyx087, Arboreal and Vault-Tec like this.
  3. Vault-Tec
    30 Aug 2015
    This guy is doing one also @David .
    Arboreal and David like this.
  4. David
    7 Apr 2009
    Yeah, I'm subbed to his channel, I love his content. He's using a NUC board and some seriously janky (read cool) adapters and thingies to get it running. It does mean he can retain both PCI slots on the back, but he couldn't get the plastic panels off though. What a noob!* :lol::p:
    I wasn't sure if it was possible to make an ITX board fit - because I couldn't find a single instance of someone else modding this particular chassis. I just figured I'd buy a dead Gen7 and try. I still have a lot to do, like accurately mark up and fit standoffs for the motherboard - I just used a big countersink bit to remove the punched standoffs in the motherboard tray. I have enough alu plate to make my own tray but I like the cool captive fixings on the original.
    *I only broke a couple of the clips to get the base plate off.
    meandmymouth, Vault-Tec and Arboreal like this.
  5. Vault-Tec
    30 Aug 2015
    Yeah very mellow channel that :) I like This Does Not Compute also !
  6. David
    7 Apr 2009
    Today, I have mostly been rewiring a microserver front IO and I discovered that my 6 x 2.5" drive cage is only a 4 x 2.5" unit, which is a bit of a pain...
    ...but now the G7 has USB 3.0
    BeauchN, IanW and Arboreal like this.
  7. David
    7 Apr 2009
    Right, just had confirmation of the LP cooler delivery, and the sanding blocks, and the paint, and the heat shrink.
    I just have to grind a mm or so off the standoffs and probably the mobo mounting screws. After that, it's just a simple matter of sanding down the chassis and panels, painting it all and then finish the rewiring. Oh, and figure out how I'm going to cable manage this beast. Also, I have, in last 4 or 5 days, managed to misplace my low profile USB 3 adapters for the mobo header. Then I have to find out where I stored my miniSAS cables.
    Yeah, a mere few moments of work before it is complete. :lol:
    Yaka, Arboreal, BeauchN and 1 other person like this.
  8. David
    7 Apr 2009
    Waiting for bits for the Gen7...
    ...but this arrived:
    Can't test it in the MS-01 yet - gotta wait for the slimline cooler from Robbee - but I chucked it on the MS-A1 to see how it fared over Oculink PCIE 4.0 x4.
    It beats the 4060LP by 10-15% and the temps seem to peg out at 70 degrees, on synthetic benches at least. Haven't messed with undervolting or overclocking yet. I think UV will be a challenge, but I just have to try.
    BeauchN, IanW, MightyBenihana and 2 others like this.
  9. David
    7 Apr 2009
  10. David
    7 Apr 2009
    OK, got home and the missus had the dinner on, so I had some time...
    Init cute?
    Paused for mac n cheese
    Behold! The mini powerhouse!!
    Runs hot though, will prolly have to re-paste and/or play with the thermal pads...
    IanW, Arboreal, BeauchN and 3 others like this.
  11. Ice Tea
    Ice Tea Multimodder
    26 Jul 2009
    @David
    Did you try the N100 as a daily desktop before it became your NAS?
  12. David
    7 Apr 2009
    Not really - it's designed as a NAS board - lots of SATA and 10GbE.
    I mean, I fired it up with a windows install just to test it out for a hour or two - it seemed like a pretty snappy little system, but I didn't hammer it with cinebench or anything like that.
    Arboreal and Ice Tea like this.
  13. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    I think the N100 performs similarly to Haswell but at a fraction of the power, obviously.
    @David what are you using the MS-01 for?
  14. David
    7 Apr 2009
    I decided I wanted a super small gaming rig but, if I can't sufficiently cool the 4000SFF in there, it'll just be a daily driver/video editing rig.
  15. Ice Tea
    Ice Tea Multimodder
    26 Jul 2009
    Arboreal likes this.
  16. yuusou
    yuusou Multimodder
    5 Nov 2006
    I appreciate what they're trying to do, keeping the mini ITX form factor and all, but:
    * No PCIe power on the PSU for expansion
    * 24 pin and CPU power cables are very short because of their specific motherboard's layout, you'd need an extension at least for a regular motherboard's CPU power
    * The top is an almost-solid piece of metal except a cut-out for plugging / unplugging the CPU fan cable, kinda crap for airflow
    * How reusable will that cooler be? X for doubt
    EDIT: These are all things I think the L in LTT would've moaned about if it were made by any other manufacturer, yet he didn't, which IMHO goes to show just how big the conflict of interest is and how blinded he is by it.
  17. BeauchN
    BeauchN Multimodder
    5 Apr 2011
    Half tempted by one of those mainboards… but I expect someone like Minisforum will do one as well, and probably with a better layout.
  18. Idioteque
    Idioteque Telephasic Mongoose
    21 Aug 2004
    From what I've read it has a unified memory architecture so for the $2000 128GB model up to 96GB of VRAM can be addressed within windows or 110GB in Linux, according to the Ars comments. Not bad if you're into your LLMs, not that I am.
    IanW and Byron C like this.
  19. Byron C
    Byron C AKA “Sticky Equilibrium” on weekends
    12 Apr 2002
    It’s an interesting idea, and if that iGPU is actually all it’s cracked up to be then it should make for a relatively potent little console-a-like, considering its size.
    But… Lack of upgrades means it’s a no from me, dawg.
    I get why it’s not upgradable: it’s a mobile CPU, and signal integrity issues make any kind of RAM socket infeasible. But the iGPU is reportedly roughly comparable to a 4060, and that’s just not enough for me to consider plonking it next to my 65” 4K TV. Not when it costs so much and I’ll never be able to upgrade the GPU.
    But it’s a neat idea, and I do respect what Framework are doing in general, so I hope they can find a market and make this work.
    EDIT:
    Aye, it’s unified LPDDR5x with dynamic allocation, which IIRC is the same setup as Apple Silicon. Nice from a VRAM perspective, because it can expand on the fly, but I’m a bit more conflicted on it as a general trend.
  20. GeorgeStorm
    16 Dec 2008
    Saw that the other day and didn't really get it, maybe I misunderstood but looked so limiting I thought what's the point of it vs other small form factor pcs, as Byron said you can't upgrade it etc so didn't make sense to me.
