News Joost is now public
Discussion in 'Article Discussion' started by Tim S, 2 Oct 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Joeymac
    Joeymac What's a Dremel?
    3 Oct 2006
    I was on the beta.. it was alright. Nothing on it I actually would watch though. The image quality is fine, it's fairly quick to start up shows. Maybe the programming has improved of late, but there are only so many episodes of "Guinness World of Records" and Fifth Gear clips you can watch.
  3. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    I suggest everyone go an watch this new show called 'Frag'. It's teh awesum.
  4. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    works very well paramount UK movies lol
    this is what thay should of been doing years ago then thay not be in the state of users allways downloading illegally
    edited
    all thay need to do is Give the users the option to Limit the uploading seems to be p2p based as well as i am uploading when watching it (the hunt for red october :) jumping an little)
    or thay run into the problem the BBC had with theres (well BBC and C4 UK had an service that kept on running when the Main program had quit when Joost is not running in the task bar it upload downloads nothing)
  5. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    pffft....... its great and all but the options of channels and shows here in Canada is ridicolously minimal.... i heard US viewers have more channels,and if they're signing up NHL, CBS, MTV, etc, that'll be awesome!
  6. leexgx
    28 Jun 2006
    you could allways just put UK post code in there or an US code over an Canada code
  7. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    i think it filters users by IP.... which sucks......
  8. leexgx
    28 Jun 2006
    works well tho needs upload limitng tho
  9. dr_bowtie
    dr_bowtie What's a Dremel?
    3 Oct 2007
    Nice program I have been using it about a month or so...the latest version 1.0 is really nice and a bit better than 0.12 that I was using...better layout and a smoother interface...
  10. evanbraakensiek
    evanbraakensiek What's a Dremel?
    24 Feb 2005
    Downloaded it after reading this news post. It looks gorgeous but has literally nothing worth watching unlike the BBC iPlayer which I've also been using for some time now, can't get enough of Saxondale and Panorama!
  11. CardJoe
    3 Apr 2007
    Yeah, but the BBCiplayer is full of malware and hidden P2P services. So is 4OD. Make sure you get rid of the hidden application Kservice.exe whenever you aren't running it - even if you turn off the player you still have to disable this process manually.
  12. Garside
    Garside What's a Dremel?
    27 Jan 2006
    Hey guys, you might recognise former editor of bit-tech, Wil Harris, on the Frag channel 'Around the net in 20 Games - Halo', oh and if you fancy seeing me check out Frag (those are teeth) :p Cheers guys.
    Edit: http://joost.com/1610001
  13. fargo
    fargo What's a Dremel?
    13 Feb 2006
    this service might be ok after beta but I"m against any type of uploading by the service. who knows
    what it could be uploading while your viewing!
  14. Bladestorm
    Bladestorm What's a Dremel?
    14 Dec 2005
    Some of the new channels are nice, the paramount movie channel is well worth a dig through, theres not a huge number of films there but some of them are classics, I think "Paint your wagon" would be one of the westerns my parents watch everytime its on and "True Grit" is ringing bells in my head .. though I'm not sure why. Star Trek: Insurrection wasn't a bad sci-fi film (not great, just not bad either) and some of the other names sound familiar too.
  15. ReelFiles
    ReelFiles What's a Dremel?
    5 Oct 2007
    Not a bad program, but doesn't look all that great on my TV. Out of all the free internet TV apps I've tried this one probably has the least lag from buffering.
Tags: Add Tags
