Peripherals keyboard buttons
Discussion in 'Hardware' started by DanSonley, 3 Mar 2012.
  1. DanSonley
    DanSonley What's a Dremel?
    20 Jan 2012
    I have a microsoft sidewinder x6 keyboard. I believe it to be faulty as it doesn't pick up light typing on certain letters. i tried sending it back but overclockers uk are being annoying about it.
    Is there a way that i could replace the actual buttons inside the keyboard because i really like it.
    i have a spare keyboard i could use but i prefer this one even though i have to correct everything because they are missing letters.
    Would be a real shame for it to go to waste
    dan
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    So it picks up heavier key presses on these keys? Are the keys near each other or completely separated?
  3. GoodBytes
    20 Jan 2007
    You can RMA it to Microsoft, if it's under warranty.
  4. DanSonley
    20 Jan 2012
    the heaver presses are picked up, and the keys are completely separated.
    and i did not know i could RMA to Microsoft. will try that.
    Thanks
  5. GoodBytes
    20 Jan 2007
  6. DanSonley
    20 Jan 2012
