Watercooling Leaky res
Discussion in 'Hardware' started by Bloody_Pete, 24 Oct 2020.
  1. The_Crapman
    5 Dec 2011
    I'd just glue it. I'd definitely be sealed and quickly.
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    What glue would you suggest?
  3. Anfield
    Anfield Multimodder
    15 Jan 2010
  4. The_Crapman
    5 Dec 2011
    Stixall. Bit of an excessive amount, but smaller tubes aren't much cheaper. Used it on a bunch of stuff to stock small persistent leaks. And random bits when clear glue was needed.
  5. Bloody_Pete
    11 Aug 2008
    Going with this Stixall, mainly because it'll ge here sooner! I'm going to try some more PTFE tape first, see if that helps!
  6. The_Crapman
    5 Dec 2011
    It's also what I used to stick the top and front glass panels of ISAC back on after the etching. lol
  7. Bloody_Pete
    11 Aug 2008
    So, I finally got to the root of the problem, there are 2 large cracks and one small cracks in the tube! I'm so annoyed as it means my PC is basically out of action, which as previously stated is suboptimal! So, Aquatuning (alphacoolings main distrubutor) sells them for around £14, but they charge £10 delivery, which I kind of resent because A: thats really expensive and B: its their product that failed! Also its currently listed as delivery in 1-2 days, which I don't know means I'll get it in 1-2 or they're expecting stock in 1-2 days. Either way, should I trust and spend more money on something that has already failed once?
    What would you suggest, as I obviously don't want to be spending loads of money, but at the same time I need to get it back up and running ASAP...
    Edit: I just realised the tube is reversible, I'll give that a go first!
  8. The_Crapman
    5 Dec 2011
    Short term: glue everything
    Long term: Watercool Heatkiller tube.
  9. Bloody_Pete
    11 Aug 2008
    That seems to have fixed it for now! So I'll just have to grab another tube for when this one inevitably breaks! I guess I'm buying my next GPU block from Aquatuning then...
    Goatee and The_Crapman like this.
  10. The_Crapman
    5 Dec 2011
    Email from aquatuning:
    TRICK OR TREAT - it is your choice:
    Discount code: AT2020H05 get 5% on all products
    (also already reduced items)
    or
    Discount code: AT2020H10 get 10% on Alphacool
    or
    Discount code: AT2020H20 get 20% on Phobya
    valid from 30.10.2020 to 01.11.2020
    Bloody_Pete likes this.
  11. Vault-Tec
    30 Aug 2015
    To be fair the cracks happened because there was too much pressure in the loop. You should definitely invest in a pressure release valve or membrane.
  12. Bloody_Pete
    11 Aug 2008
    I don't have to now, I have those cracks at the top to do it for me :hehe::hehe::hehe::hehe:
    Vault-Tec and The_Crapman like this.
  13. Vault-Tec
    30 Aug 2015
    lmao true :D
