News LEPA HDB 120 watercooling system leaked ahead of Computex
Discussion in 'Article Discussion' started by brumgrunt, 29 May 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. The_Crapman
    5 Dec 2011
    Quote "there's no need to add anything else to the system - and, indeed, it's impossible"
    Oh no it's not! ;-p
  3. Gareth Halfacree
    4 Dec 2007
    Hah! I should have said 'designed to be impossible' - that's worth going back and adding a link, that is... Ta
  4. Kamikaze-X
    Kamikaze-X Minimodder
    24 Apr 2009
    I can see this flopping, mainly because us lot are a vain bunch. It's ugly as sin! Makes the corsair stuff, even the H50, look like supermodels.
  5. The_Crapman
    5 Dec 2011
    And then there's the association with leprocy......
  6. The_Crapman
    5 Dec 2011
    Awesome! :D thanks for the ego boost! lol
  7. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    why is it that we still cant expand on the images used in these types of publications?
  8. mi1ez
    mi1ez Modder
    11 Jun 2009
    how thin is that tubing? can't get much flow, surely!
  9. feathers
    feathers Minimodder
    11 Apr 2009
    I have a german mini NB/VGA waterblock that uses 6mm OD choobing. The waterblock has side mounted holes and is about 3mm thick except for where the tubes connect which is about 6mm cylinder. The block cooled as well as the full sized versions.
  10. mrdbristol
    mrdbristol Voided my warranty years ago
    8 Aug 2008
    :D
Tags: Add Tags
