Notebooks LG Notebook not detecting HDD.. Help pls
Discussion in 'Hardware' started by Jhonyb, 6 Jan 2008.
  1. Jhonyb
    Jhonyb What's a Dremel?
    5 Feb 2007
    Hey
    I just formated and made a partition using Partition Magic 8.01.
    After it was done i inserted the Windows XP it booted and then i pressed ENTER to continue and it says:
    "Setup did not find any hard disk drives installed on your computer"
    And then asks to reboot!
    What can i do to RE-install windows????
    thx in advance
  2. GoodBytes
    20 Jan 2007
    That is our dear old WinXP!
    Your HDD is probably SATA, and requires SATA drivers.
    The fix:
    - Get an eternal USB floppy drive and a floppy.
    - You need an other computer to find, download, and extract (if zipped) the SATA drivers.
    - Plug your external floppy drive into your laptop.
    - When Windows XP goes "Press F6 to install SATA or RAID driver...." (or something like this) [you have about 1-2 second]... press F6.
    - Tell windows setup to install the SATA drivers and you are set to continue the setup.
    If you have 2 GB of RAM, a Vista compatible video card that won't struggle and peek at 100% to draw the interface, and a good CPU, get Vista.
