Case Mod - In Progress LIAN-LI PitStop T60 Red
Discussion in 'Project Logs' started by Corsaronero333, 10 Mar 2012.
  1. Corsaronero333
    Corsaronero333 What's a Dremel?
    25 Feb 2012
    The work now is to put the cable in the support of the motherboard to avoid having to make turns vicious and sata cables that power the card.
    Further ado let's start:
  2. Corsaronero333
    25 Feb 2012
    Now one thing that I love to do ..... the slevving
  3. Corsaronero333
    25 Feb 2012
  4. Corsaronero333
    25 Feb 2012
    tart doing the sleev supply but with the proper tools
    First you need to open the power supply, be aware that this is' void the warranty.
  5. Corsaronero333
    25 Feb 2012
    Once open take off my socks, trying not to cut the original wires below
    Divido per bene i cavi , che non vadano a creare incroci non voluti
    And in the end I set up my support in this case the red 24-pin
    This will help me 'to do the skinning thread by thread to mistakes without incurring the risk of accidental burning power
    Work plan, enlightened and orderly
  6. Corsaronero333
    25 Feb 2012
    We're here to finish the 24-pin + 8-pin ATX, and we are just in the middle 'of the work
    Looking good I stayed out of the hole the last 8 of the cables' motherboard power.
    Not wanting to force others I decided to make a new passage, the advantage is enormous, all cables are free and are not going to choke in the edging.
    Protected from before all the interior with the paper, to prevent the accidental entry of processing residues, I create the axis for drilling with a hole saw 19mm.
    A hole made ??take away 'the so-called burrs sharp needle with a lime, do the test of the plastic collar, and I do the last step remaining cables,
    the work is finished it seems to me aesthetically acceptable
    Power
  7. Corsaronero333
    25 Feb 2012
    Opssss forgot him to frets sleev Power / Reset / HDD LED /
    once we recruit
    Add 2 photos of the hole drilled in the back of the banquet for the passage of the 8 wires of the motherboard
  8. Corsaronero333
    25 Feb 2012
    I'll get 'inspired by shark fins .. so nicknamed by some, to make a change to the outside of ALI also aesthetic, placing a piece of carbon palxy obscured laterally by then will be 'red light
    We look between the carbon that can 'help me
  9. Corsaronero333
    25 Feb 2012
    Let us pick up the AC moddandolo properly, first I will have to 'play the plaxy double-sided tape that will go' all around all'ali
    Then I place it and prepare the top one where we find the fan 140mm
    We begin to cut and polish the edge, always with the affectionate DREMEL
  10. Corsaronero333
    25 Feb 2012
    Coating and Painting
    Power
    With these photos end up on the food industry, I hope you enjoyed.
    All this work to point out that tiny bit of 3mm all around all'ali
  11. Corsaronero333
    25 Feb 2012
    In the basic arrangement of the LEDs has been improved to have more 'homogeneity' of the light will spread 'in plaxy, LED strips are coupled so doing will reflect the light' on both sides.
    And here we are at the first stage of final assembly .......
  12. Corsaronero333
    25 Feb 2012
    Here lords spend '2 words more' I want you to see how I positioned the tank Dagored gave me for Christmas, I work very difficult and delicate, I had to make a new thread the tank in a dangerous position moltoooooooo, err meant to throw a piece, but in the end everything went well, I used to support steel tubes drilled and tapped M5 always to attack the eyelets of stainless steel.
    The photos are very basic, and free of background, but for that you will 'time, you just have to show yourselves the idea of ??how it came to the job.
    Thanks to Ermanno
  13. Corsaronero333
    25 Feb 2012
    Before you post photos say not definitive but a good beta, I will post the WB of the Black Sun Ybris known Italian company leader in watercooling.
    Wb This was given to me at Christmas by the owner and I think it was a joy for me is not indifferent and I'm proud to be able to edit I asked if he had no objection and an answer Make it what I was told 'you want at this point begin the work
    first
  14. Corsaronero333
    25 Feb 2012
    after
    You will not do 'full carbon support, because the existing bracket is made of stainless steel, at this point I wanted to create a kind of twinning between steel and carbon, I think it gets at something pleasant
    I prepared a sheet of carbon from 0.5 glued to the steel and from here all the work
  15. Corsaronero333
    25 Feb 2012
  16. NoobNeb
    NoobNeb Enthusiastic Lurker
    14 Nov 2011
    The frosted acrylic lights up so well, theres a lot of good work here :jawdrop: youre definetly a master modder :clap::clap::clap:
  17. Corsaronero333
    25 Feb 2012
    We start with arranging the avalanche of wires that abound in the back, to do this I created a support that will go 'to make order, dividing power supplies 12v and 5v, hope you like the solution I adopted
    With cable Nils then I solved the problem of having tubes and wires around the mod
    Here's what I mean by order
    I'll post it to the power cable sleev fact required to be picky friend ...... is now happy.
    Waynio likes this.
  18. KidMod-Southpaw
    28 Sep 2010
    Wonderful, all of it.
  19. Corsaronero333
    25 Feb 2012
    Thanks, the acrylic has a circulation of spectacular light that the photo does not make :)
  20. Corsaronero333
    25 Feb 2012
    Thanks, I'm glad you like it all
