Peripherals Longweight's Mechanical Keyboard Guide
Discussion in 'Hardware' started by longweight, 23 May 2012.
  1. GeorgeStorm
    16 Dec 2008
    They sound gorgeous, worth the money just for that in my opinion.
    May have to look into getting a set.
  2. longweight
    7 May 2011
    I will let you know how I get on with modding mine, need to buy a Dremel and a small vice now!
  3. GeorgeStorm
    16 Dec 2008
    Mm, I'm not a massive fan of the look, so wonder if thick PBT caps have a similar sound/feel or not. May have to look into it.
  4. longweight
    7 May 2011
    I think the noise comes from the material and the weight so think PBT caps might not do it.
  5. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    They honestly do sound fabulous. Imagine those on a buckling spring..
  6. longweight
    7 May 2011
    Heh :D
    Well when I get my aluminium caps I will do a full typing test on the Filco with browns and the Noppoo with blues :)
  7. KidMod-Southpaw
    28 Sep 2010
    I cannot wait! Also, if I don't like blacks, I'm straight away putting down interest for your Noppoo with blues! :D
  8. longweight
    7 May 2011
    That sale depends on me finding a white Filco TKL ninja with blues :p
  9. longweight
    7 May 2011
    Some much better images of the aluminium key caps have been added :)
  10. Jester_612
    Jester_612 "Jammy..."
    14 Nov 2011
    I figure you are one for exacting standards, so you'll want to update the layout section with the ` key being grave accent I think. :)
  11. longweight
    7 May 2011
    So it's called the grave key? Rep for you my friend! Thanks!
  12. Nexxo
    23 Oct 2001
    Yup; you have:
    grave accent (accent grave): è
    acute accent (accent aigu): é
    circumflex accent (accent circonflexe): ê
  13. longweight
    7 May 2011
    Thanks Nexxo :)
  14. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    I have just looked through this thread, and from what you have said Sir Longweight BROWNS are the best choice for those new to mech keyboards. I am in the market for one xD
    I am ot a very good typer. I can't touch type or really look at the screen whilst I type at least on a keyboard. Too many years using a laptop. I'd prefer full size rather than a smaller keyboard.
    Price wise I am willing to take the higher end price. Will be coming from a Cyborg V5. Which is an ok keyboard.
    One question with any of these mechanical keyboards would i be able to press multiple keys at once?
    And which manufacturer would you recommend?
  15. longweight
    7 May 2011
    I would always recommend Filco as a first board, great quality and lovely to look at! Cost is around £120 for a full size board with browns, would you need UK layout?
    Most mechanicals have NKRO so you can press as many keys as you want, quite a few cheaper boards don't though so it is always worth asking before buying!
    Is £120 too much?
    MrDomRocks likes this.
  16. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    £120 isn't too much and I was thinking Filco having read the Mech KB Thread at least partialy in the past.
    UK Layout is preferred XD
  17. longweight
    7 May 2011
  18. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    I was just looking at that website :thumb: Probably going to buy it at the weekend xD
    I like to give things time before I go out and buy them. Simply as I am controlling impulse buying.
    I bought my SSD at 3am because I decided I wanted one. Oh and Diablo3 the other day another impulse buy.
  19. longweight
    7 May 2011
    I know the feeling! I spent £100 on caps this morning, that was meant to be my weekend money!
  20. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Opps I will spending money out of my savings which I will then replace. As I have a job I can justify it!
