Case Mod - In Progress Macintosh Atom(?)
Discussion in 'Project Logs' started by vils, 29 Nov 2009.
  1. vils
    vils What's a Dremel?
    4 Jun 2006
    I built my wife a comp a year ago, based on a Intel atom board and some leftovers.
    The result is a well working but not so good looking object:
    But I've just got my hands on this one:
    A Macintosh IIcx, my plan is to fit all current internals of the ghetto mod into this lovely case.
    Apart from the PSU wich won't fit. It's almost a shame to go for a mini-ITX board since a mATX will fit, but finance limits me to what I already got.
    I will try to get a slot loading dvd though since I will try to make minimal work on the outside of the case. Just widening the floppy port would be the best way to go.
    Here's some pics of the new case:
    Plans are brewing...
  2. Ryan Cooper
    Ryan Cooper It's been a long time.
    25 Jun 2008
    Liking the Idea. You've got a follower. One question though, are you gonna make that slot in the front (which I'm guessing was for a floppy drive) bigger, or are you going to seal that up and make a completely new one?
  3. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    Time for a modd in it !:thumb:
  4. jrs77
    jrs77 Modder
    17 Feb 2006
    Nice catch on the case, as it has basically all interiors allready done to simply mount the new hardware into it.
    I'll be watching this ;)
  5. vils
    4 Jun 2006
    Just widening the original floppy slot. I only need to make it one inch wider. And that won't compromise the original looks.
    Thanks for the comments to you and Raiden.
  6. Jelle46
    Jelle46 Belgium
    14 Feb 2009
    looks promising, nice ghetto-mod btw, was your wife happy with it :d
  7. Singularity
    Singularity ******* Operator from Hell
    2 Mar 2008
    Oh, like it! Your "old" box looks quite like my skeleton case (the mod is still alive, I just can't find the time to finish it :D). Can't wait to see what you make of this :)
  8. jhanlon303
    7 Sep 2006
    I love putting PCs into other people's products. I watch.
    john
  9. null_x86
    null_x86 Thread Closer
    18 Jan 2009
    im watching this
  10. Matticus
    Matticus ...
    23 Feb 2008
    I will be watching, from a tree outside your bedroom window!
    If you are planning to hackintosh on the software side, be warned that OSX was updated to not allow atom machines to boot. Not sure how easy this is to get around (probably just not updating :p)
  11. null_x86
    18 Jan 2009
    its already been fixed, that story was last weeks news. I have 10.6.2 on my mini and its working fine. [/hijack]
  12. Nexxo
    23 Oct 2001
    Because we need pics of work in progress. And when you have, let me know and I'll move it back to Projeft Logs.
  13. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    For obvious reasons, I like this (I'm doing something similar with an IBM case)
    Is the apple a working system? Would be a shame if it were to destroy it, but I like the idea none the less!
  14. vils
    4 Jun 2006
    Ok, this have been on ice for too long. My Facit project exhausted resources and energy but now things are on the move.
    I don't know if it worked since I had no possibility to check it. Now it definitly don't work, but I still have working MacClassic in storage.
    Thanks, parallel with this I'll be working with a IBM 8570 case.
    Well, here are the progress so far.
    All hardware was ripped out of the case and all odd plastic stands were trimmed off.
    I have enlarged the floppy-slot so it can be used for a slot-in Blu-ray burner. The bottom of the case is now lined with an aluminium plate for mounting Mobo and all other devices.
    Basic planning:
    I don't want to change the exterior of the case to much so all i/o ports will be housed in the original holes with cables attatched to the mobo.
    The original 0n/off and reset buttons were mounted directly to the mobo pcb (activated with plastic pins from the front of the case). I salvaged some nice clicky switches from an old VCR that I will mount in some way.
    The computer will be used as a media server so I'm looking for a itx-board with hdmi and that are not too heat producing.
  15. vils
    4 Jun 2006
    The last days I've been playing around with card-board mock ups in the case and tried different positions of the hardware.
    There are plenty of room but not in the right places, this will be tricky to get right. But challanges like this is one of the reasons for that I like cramming new stuff in odd old cases.
    Nostalgia might be another one.
    I'm now contemplating to use a PicoPSU with a 12v AC-DC converter housed inside the case to get some more flexibility with the inside logistics.
    Both SFX and Flex PSUs poses tremendous placement problems.
    Any good ideas a welcome.
  16. jrs77
    jrs77 Modder
    17 Feb 2006
    The SFX-PSU should fit nicely, if you turn it by 90°. It has only 125mm width, but yeah, a picoPSU would make it even easier to place the components, and it wouldn't be much more expensive either.
  17. lew0808
    lew0808 What's a Dremel?
    26 Nov 2012
    love the idea, I'm watching this.
  18. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Look at all that EDO RAM lmao. :)
  19. vils
    4 Jun 2006
    Now it does. I have chiseled away the plastic 'grid' from parts of the case's bottom and now have exactly 125mm.
    I did intend to show you some pics of this painstaking chore but for some reason I no longer can transfer pics from the phone to the computer. I can hopefully solve this until tomorrow.
    Apart from blisters in my palm I have also produced a stand for the internal on/off and reset buttons.
    But more about this later when I can post pics again.
  20. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    That puppy maxed out at 20Mb of ram!!
