Macro LCD
Discussion in 'Article Discussion' started by Koolvin, 21 Oct 2001.
  1. Koolvin
    Koolvin The Modfather
    12 Mar 2001
  2. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    :eek: Very Nice! :eek:
  3. RTT
    RTT #parp
    12 Mar 2001
    NEEEEEEEEEEEEEEEEEEEED!!!!!!!!! :cool:
  4. Fly
    Fly inter arma silent leges
    31 Aug 2001
    niiiiiiiiiice....
  5. Cheese
    Cheese Doc
    6 Oct 2001
  6. RTT
    RTT #parp
    12 Mar 2001
    if it was possible, the wires should have gone down the little tube and out of the back (if they could be fitted in of course), it'd look neater i think, oh and also if the wires at the back were in black heatshrink :cool:
    heh dont get me wrong its a kick ass mod, all points to macroman!
  7. macroman
    macroman The One
    3 Sep 2001
    Ok Ok! I'll strip it down and start again. Huh! :D
    Some people! :rolleyes: :D
  8. Hi-TEK
    Hi-TEK What's a Dremel?
    7 Sep 2001
    Genius.. wondering if Macroman is defecting from Razor-Tech over to Bit-Tech. Good use of 634 20x4, I have two Crystalfontz units and they are great to work with. I agree with Rich that the wires should have come out of the shaft of the old Creative microphone stand to make it look a little neater. Overall its a kick as mod and sets a standard for external LCD displays.
  9. vivid
    vivid down in fraggle rock
    24 Sep 2001
    what a beut!
    i think macroman shoul;d go into buisness and sell all his mods, he'd make a packet
  10. Koolvin
    12 Mar 2001
  11. Cheese
    Cheese Doc
    6 Oct 2001
    That's quite possible (college connection) - so is there no soln to this? Am I really not going ot be able to read your articles and see your pictures in future :( :( :confused:
    r.
  12. SuperScrubber
    SuperScrubber Mad Chemist.....buwahahaa
    12 Mar 2001
    Cant get the piccies either (same network as cheesy rob) but..........:(
    Firewall blocks
    Currently the following ports and/or IP addresses are blocked:
    Protocol Port IP number Netmask Service Reason
    Redirects
    TCP 80 http redirected to proxy cache (except specific IPs listed below as blocked)
    Security Blocks
    TCP 1 tcpmux SGI security risk
    TCP/UDP 1-19 small services unnecessary and various security problems
    TCP 25 smtp incoming restricted to specific hosts.
    Outgoing unrestricted (but see note)
    TCP 53 dns blocked except to the official DNS servers
    UDP 67 bootps DHCP server
    UDP 68 bootpc DHCP client
    UDP 69 tftp insecure trivial file transfer protocol
    TCP 87 link CERT recommendation
    TCP 98 linuxconf Linux security risk
    TCP 109 POP-2 security risk and superseded by POP-3
    TCP 111 sunrpc portmapper/rpcbind
    TCP/UDP 135-139 NetBIOS OxCERT recommendation
    UDP 161 snmp access/control
    UDP 162 snmp-trap
    UDP 177 xdmcp Red Hat Linux vulnerability
    TCP/UDP 445 Win2000 NetBIOS OxCERT recommendation
    TCP 515 lpd security problems
    TCP 540 uucp CERT recommendation
    TCP 1080 socks proxying & laundering of connections
    TCP 3128 objectserver SGI vulnerability
    TCP 5232 SGI GL daemon believed to be used to identify SGI machines prior to attacking them
    TCP 40193 Netware 5 DoS attack
    Means little to me but one of you might know whats up.
    Picture on the frontpage looks very cool indeed...........kind of wish I'd gone more in debt now to get the bigger display instead of the 2x20 I've got.
  13. Forsaken
    Forsaken GameFaction.com
    27 Mar 2001
    looks mint,
    i dont think macro could have put the wires down the shaft of the ex mic, cos the serial cable would be a bit too phatt, but i may be wrong.
    I had to reload nearly all the pics in the article, but they worked the 2nd time
  14. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    half way down i had to tell all teh images to show image ... then they loaded fine :confused:
    oh well ...
    Nice one macroman, I dont quite understand exactly where you connected the second wire from the manual contrast knob.
  15. macroman
    macroman The One
    3 Sep 2001
    Right, the hole the wires run through is 1.5mm the stem is less than 2mm thick. If I could, I would have run the serial and power cables through it, but even using thinner wire would have been too thick. The power cable has to carry about 0.7Amps!
    Spike- the preset has three contacts, the wiper goes to R8 as shown the other two, one goes to 0V the other to 5V. I just picked up the appropriate voltages off the board.
    Images load fine for me.:eek:
  16. ChriX
    ChriX ^
    30 Aug 2001
    Hey macro, is that backlight going through any resistors or is it just connected straight to 5v, mine gets a bit hot at 5v.
  17. Digital Fodder
    Digital Fodder What's a Dremel?
    30 Aug 2001
    Macroman... a nice simple question for ya, where did you get the black casing for the LCD? i might hve missed it, but does it come with the LCD?
  18. Lordflash
    Lordflash What's a Dremel?
    27 Aug 2001
    Is nothing safe from macroman ? wonder if the bods at creative though a mic could be put to an even better use ?
  19. macroman
    macroman The One
    3 Sep 2001
    The box is from Rapid Electronics stock code:30-2070 and no. it doesn't come with an LCD. You have to win that. :D
  20. Guest-16
    Guest-16 Guest
    That is some seriously nice work!! whow..... /me weeps at my pathetic modding knowledge :(
Tags: Add Tags
