Macro LCD
Discussion in 'Article Discussion' started by Koolvin, 21 Oct 2001.
  1. macroman
    macroman The One
    3 Sep 2001
    Well maybe but in the article that this thread refers to there are no tables. :D
  2. y-it-earp
    y-it-earp What's a Dremel?
    13 Mar 2001
    Surely you are gravely mistaken!!
    My mate bob reckons the tables one of a kind, as does his mate bill and his mate........er.........barney
    So respec the table :D
  3. firewars
    firewars What's a Dremel?
    14 Oct 2001
    Seriously now..
    Would you sell me such a LCD?
    They are just toooooooooooooooooo impressive .. pleese :D
  4. A[L]C
    A[L]C What's a Dremel?
    23 Oct 2001
    oi im first to buy it :D
  5. firewars
    14 Oct 2001
    Lemme make you a deal:
    My ASUS A7M266 mainboard for that LCD ..
  6. Novgorod
    Novgorod What's a Dremel?
    5 Nov 2001
    hi! your LCD mod is REALLY impressive :)
    I have a LCD in my suitecase-mod, too :) (here u can see it if u want (4MB divX) and here is the suitecase :))
    I dont know if it has been already asked, but I think, the software U used for the display is as cool as the display itself :).. so where can I get that software for my 16x4 LCD?
  7. Koolvin
    Koolvin The Modfather
    12 Mar 2001
    welcome!!!
    the software is lcdcentre from boderfield.com
  8. Novgorod
    5 Nov 2001
    hmm i have the borderfield software but it has problems with my 16x4 HD44780 LCD (no matrixorbital..) :( ..the rows 3 and 4 are displayed 4 chars more right (sorry my bad english, i'm from germany ;))
    the borderfield software is very slow, too (the scrolling is very bad...)
    i have a winamp plugin for the mp3 title and visualisation and it's very great and fast.. (video above..)
    so, does anybody know a software specially for HD44780 LCDs whitch shows most of the stuff that the borderfield software shows, too... (temps, up time, networktraffic are the most important..)
  9. Gordy
    Gordy Evil Teddy
    17 Apr 2001
  10. Novgorod
    5 Nov 2001
    hmm the LCDriver seems to be only for serial LCDs.. also it has no further options so far (like temperatures etc..)
    i have running the borderfield software at the moment showing the upload, download, CPU speed and up-time, but the rows 3 and 4 are still displayed wrongly (4 chars away from the left end...)
    also the borderfield software cannot show the temeratures (on my macheine...)
    so plz give me links to other progs if u know some...
  11. macroman
    macroman The One
    3 Sep 2001
    Lcdcentre uses mbm to monitor temps. So you need to run that as well. MBM can be found .here
    Use the configuration program and make sure there are no leading spaces programmed in the up/down stream parameters. I think there may be some by default
  12. Novgorod
    5 Nov 2001
    thx @ macroman ;)
    the problem with the rows 3&4 does not depend on the values.. EVERYTHING i want to display in row 3 and 4 is displayed 4 caracters away from the left end of the display.. I think it's an error of LCDCentre because the winamp plugin works very well with the rows 3 and 4 ...
    ok, thanx so far @ all ;)
  13. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    As macroman says you can edit the settings so it should appear in the right place , and you need MBM 4.0 or greater to show the temps . The config program is sometimes a bit sucky you can do it all in note pad with a little look at the existing settings :)
  14. firewars
    14 Oct 2001
    Darn I am almost complete "remaking" that modification (making it as well) but I can't find a box that fits.
    Where did you find such a good fitting box?
  15. macroman
    macroman The One
    3 Sep 2001
  16. firewars
    14 Oct 2001
    Thanks for the information and damn you :D
    I just bought a box that does not fit totally , though.
    Will have to glue it then .. umm ..
  17. Novgorod
    5 Nov 2001
    k, by manipulating the ini files of the borderfield software i could make the dely times much shorter ;)
    but i didn't find any value for the position of the caracters.. also the values for the display sizes were alright (16x4) in the ini, but the rows 3 and 4 are still displayed wrong :(
    so i found a prog here (LCD proc) .. it's a linux prog whitch i wished to have.. but i need a win2k oder winnt version for HD4478 PARALLEL LCDs... if anybody knows.....
  18. Quinten
    Quinten What's a Dremel?
    20 Jul 2001
    soon... :D
  19. Novgorod
    5 Nov 2001
    ?!? *hope* :D please give me further informations ;)....
  20. Quinten
    20 Jul 2001
    Not yet :)
    Q.
Tags: Add Tags
