Just got a load of the Lian-Li infinity fans for my build and the L connect controller box comes with sticky tape and I'm not keen on this and was thinking of sticking magnetic strips to the back so I can move it with ease, my question is will this be OK and not damage anything. Thanks
It'll be absolutely fine. The adhesive mag strips aren't super powerful neodymium magnets, with large magnetic fields. Corsair use magnets embedded in their RGB LED strips.
I've attached a fair few hubs with magnetic strips, some even get supplied with them. Never seen them cause an issue.
Lovely, clean build. I went the same way too, albeit with the 5000D airflow. I finished off my AIO pipes with some hose clamps to keep them parallel, similar to these: https://www.amazon.co.uk/Aluminium-Display-Fittings-Connector-67x25mm/dp/B07HF572BJ/ref=sr_1_17?crid=1YUCM2RH7F0AY&keywords=double+tube+clamp&qid=1682426149&s=diy&sprefix=double+tube+clamp,diy,68&sr=1-17
