Electronics Making a switch do the oposite
Discussion in 'Modding' started by THEkorean, 13 Jan 2008.
  1. THEkorean
    THEkorean 42
    10 Jun 2005
    So, I bought a key switch, and it's not doing what I want it to do. When I do not put the key in and turn it, it is in the connected position. When I put the key in and turn it, it is in the 'kill circuit' position. At this point the key is locked in and wont come out until I turn it back to the 'connected' position.
    Now, what I need to do is to wire it so it reverses the switch so that the opposite happens (so that key turned will be 'connect' and key out would be 'kill'). This is to arm and disarm the power button to my PC.
    On the back of the switch there are 2 solder points.
    Any idea how I would achieve this?
  2. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    can you take some photos?
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    With only two tags (ie, single-pole, single-way) you can't wire it any different; only thing possible is to use that switch to operate a relay change-over switch.
  4. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    yeah youd have to program something or use a relay. Probably cheaper to buy a new switch.
  5. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    You could wire it in parallel with whatever you're turning on.
  6. weasal
    weasal What's a Dremel?
    22 Jul 2007
    If you got a 5v power supply you could use a TTL 7404 IC which is a hex inverter and get the signal from the switch through that to give you the opposite
  7. THEkorean
    THEkorean 42
    10 Jun 2005
    I don't really want to mess with relays. Would what Ending Credits says work?
  8. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    Perfectly, for the tenth of a second or so before the fuse in your power supply blew. The easiest thing for you to do would be to buy a new switch, making sure it works the way you want.
  9. perkins teh modder
    perkins teh modder What's a Dremel?
    8 Dec 2007
    where did u buy the key switch from?
  10. THEkorean
    THEkorean 42
    10 Jun 2005
    Hrm, seems like my best bet is to get a new switch. OK, thanks for all the help guys!
    @ perkins:
    got it from allelectronics.com
  11. perkins teh modder
    8 Dec 2007
  12. Ending Credits
    4 Jan 2008
    Haha, I didn't think about that. :p
