Cooling MATX Cooling conundrum
Discussion in 'Hardware' started by SuperHans123, 19 Apr 2015.
  1. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
    Hello all.
    I am about to purchase a Silverstone Temjin TJ08 mATX case.
    I will be installing an AIO cooler on the rear 120mm slot.
    As the front fan will be bringing in cold air from the outside, won't it 'clash' with the air being brought in at the rear to cool the AIO?
  2. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    You can mount the fan on the AIO rad to exhaust.
  3. SuperHans123
    27 Dec 2013
    I realise that BD but was concerned that this would then be exhausting 'heated up' air over the rad.
    Or would be this a non issue due to the positive pressure set up of this case?
  4. bdigital
    10 Aug 2010
    Nahhh its cool.
  5. Bradley8988
    Bradley8988 What's a Dremel?
    16 Jun 2008
    Could always have front as exhaust.
  6. Parge
    16 Jul 2010
    This.
    Also, your GPUs are at the top, so the big 180mm AP at the front will push cool air directly into the path of your AIO.
  7. SuperHans123
    27 Dec 2013
    Thanks for the advice all.
    Removing the HDD cages was part of my plan as I only possess two SSD's and no mechanical drives.
    Should the 120 fan on the AIO come 1st or 2nd in order from inside the case? Or does that not matter at all?
  8. theshadow2001
    3 May 2012
    I would have the rad exposed to yourself for easy cleaning. So pull I suppose. Or put one of them dust filters on it and do what you like.
  9. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    Realistically, it's so flush against the radiator either way that it shouldn't make much (any?) difference. I'd do whichever makes the AIO's pipes fit most naturally.
    SuperHans123 likes this.
  10. SuperHans123
    27 Dec 2013
    Will go for the push kipper.
  11. ak_2020
    ak_2020 Minimodder
    22 Nov 2010
    push configuration will be *slightly* better at cooling...but pull will be easier to set-up.
    When I ran a TJ08-E case with a H50, I set it up in pull...Temps were fine. As long as you remove (or at least don't fill) the drive cage you'll have no problems with CPU temp.
  12. SuperHans123
    27 Dec 2013
    Cheers m8
    Will be removing the HDD cage completely.
