CPU Maxing Out My Computer
Discussion in 'Hardware' started by FTZP, 31 Dec 2011.
  1. FTZP
    FTZP What's a Dremel?
    31 Dec 2011
    hi guys. I want to know everythign that I can add to the following computer to make it the fastest possible in its class / age / or generation
    Here are my specs from the receipt
    Intel Core 2 Quad Q8300 2.5ghz 4mb 1333 MHZ 45 NM LGA
    Intel BLKDP45SG p45 S775 c2d quad 1333 mhz ddr3 1333 2
    Kingston 2gb ddr3 133 mhz non ecc kvr 133d3n9/2g
    Western Digital 500 gb 7200 rpm
    Inno 3d gts 250 1 g dd4 256 bit vga dvi hdmi
    windows home basic 7 32 bit english oem
    Thermal take litepower 430 watts
    Now I want the best in class that can be supported by my motherboard
    1. Processor
    2. Ram
    3. HDD
    4. Graphics Card
    5. Software
    6. HDD.
    Thanks need all your help.
  2. jizwizard
    jizwizard Modder
    24 Dec 2010
    Why? The money you would spend maxing your rig would be a waste. You could get a sandybridge setup for less. What do you intend to do with said build
  3. towelie
    towelie How do I Internet!!
    1 Sep 2011
    ^Agreed If you really want to improve that rig maybe a better cooling solution and some overclocking on the CPU and RAM. Depending of what you want to do of course as modern gaming looks like a no no.
    I'd put it to better use make it a server/NAS/Backup PC and throw some hard drives in it
  4. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    If you want a good (cheap) performance boost, upgrade the RAM to 4Gb.
    Having said that, it all depends on what you want to do with this computer - playing games or just surfing the internet?
    You could also upgrade the graphics card, change to Windows 7 x64 Home premium..
  5. tonpal
    tonpal What's a Dremel?
    27 Jul 2008
    As oasked has said how and what you upgrade depends on how you use your computer.
    As a general comment an upgrade to the graphics card or adding a SSD would be sensible first steps as they will be compatible with a newer CPU / motherboard. Memory is cheap at the moment so although it would become obsolete when you upgraded the CPU it may be worth investing in another 2-4 GB now.
  6. crosshair
    crosshair It's life Jim but not as we know it
    12 May 2009
    +1. Also, an idea of your budget would help, and you don't mention your monitor. In any event, if it's for modern gaming, then you should really start with an i5 2500k and work from there.
  7. DanSonley
    DanSonley What's a Dremel?
    20 Jan 2012
    i would say go sandy bridge aswell.
  8. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    Seriously, it's a waste getting hardware 3 or 4 generations old, as the high end stuff from then has only been getting more expensive.
  9. leslie
    leslie Just me!
    19 May 2009
    Have you looked at the price of memory these days?
    DDR2 is sky high... Close to 5 times the cost of DDR3.
    In many cases it's cheaper to buy a new board and memory than it is to work with DDR2. Then there is the fact that you are stuck on Sata2, which eliminates half the advantage an SSD would give you.
    First thing to do, is get rid of DDR2, you will be pouring money into a bottomless pit with ddr2 and 775. While a Q9550 or so will get you older I5 speeds, you are going to put all of this into a board that is way behind already and ANY upgrade after this will require a board anyhow. Ditch your board before anything else.
  10. BlackDrag0n
    BlackDrag0n What's a Dremel?
    3 Nov 2011
    My Agility 3 on Sata2 does everything a lot quicker, so no, I would not say it eliminates half the advantage. The only time a SATA3 will out pace a SATA2 is on sequential read and writes - most everyday usage is the 4K Random read/writes.
    OT: Like everyone else said, go SB. If your budget supports it - else go with an SSD.
  11. longweight
    7 May 2011
    You should ditch your old stuff and just save for a new build, no point putting high end stuff with the rest of your kit.
  12. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    Start again. Use Ebay to sell the bits you have.
    It would be throwing good money after bad.
  13. leslie
    leslie Just me!
    19 May 2009
    Yeah, I thought that too until I went Sata3.
    I'm not saying an SSD on sata2 is terrible, it's a nice jump over conventional drives, but moving from sata2/ssd to to sata3/ssd, is just as big of a jump, or more.
  14. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    I'm very tempted to say :
    "Please don't feed the trolls"
    But can't decide if its genuine or not.
  15. boltonuk007
    boltonuk007 What's a Dremel?
    29 Sep 2011
    the most I would be willing to do with this setup is putting more RAM in and then maybe a GTX560, not worth spending money on really.......even though Iam pretty sure hes a troll
  16. boltonuk007
    29 Sep 2011
    hes either a troll or has been really out of touch with anything released in the last 4 years
