Peripherals Mechanical Keyboards
Discussion in 'Hardware' started by Raptor77, 27 Dec 2011.
  1. The_Crapman
    5 Dec 2011
    It it possible to replace springs on non hot-swap keyboards? Got the refund through for the K4, but can't justify a replacement at the minute, so looking to spruce up my cm storm xt. Thought some heavier springs and a cheap set of caps would do the trick for now.
  2. David
    7 Apr 2009
    Yes, but it's a ball-ache. It used to be a fairly simple affair with a few bent bulldog clips but plate mounts and LEDs mean you have to break out the soldering iron to access each switch.
  3. The_Crapman
    5 Dec 2011
    The xt is boggo basic board, no LEDs. Not sure what the situation is under the hood. Will pull it apart and have a look once I've tidied the office. It's an absolute **** storm after the build over the weekend.
  4. wyx087
    wyx087 Multimodder
    15 Aug 2007
    I found this website that can filter for backlit lettering + PBT + UK ISO. Looks like TaiHao is the only option and the cream/gray set I prefer is the only one out of stock :(
    https://www.kustompcs.co.uk/periphe...es/mx-keycaps/?features_hash=76-6287_163-8037
    This set is out of stock everywhere:
    https://www.overclockers.co.uk/tai-...m-grey-iso-ansi-140-keycap-set-kb-02u-ta.html
    This set is 98% compatible with K4, only 2 keys not compatible is End and page down not on R4. But there are R4 blanks or I can use R3 and see if it makes blind feel easier, I'm still trying to get used to hitting those keys correctly.
  5. The_Crapman
    5 Dec 2011
    These are abs, but cheap enough to buy a couple of sets to make one with the make-up you want. https://www.amazon.co.uk/dp/B0736KVNK1/ref=cm_sw_r_apan_i_VV2PH0Y938Z2JPA5ETTE?psc=1
    Got my XT apart
    PXL_20220408_184300518
    I take it this is plate mounted and I'm boned?
  6. David
    7 Apr 2009
    Yup.
    Start warming up that soldering iron and set aside an entire weekend.
  7. The_Crapman
    5 Dec 2011
    Really annoying thing is I know I had a pump, but can't find it. I may have binned it. :rollingeyes:
  8. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    If you're talking about one of those hand pump things.... :eeek:. I de-/re-soldered all the switches on a TKL at some time last year and even with a desoldering station it was a ballache. Doing it "by hand" with one of those little pump things.... yeah.... you will want an entire weekend!
  9. The_Crapman
    5 Dec 2011
    I've bought a cheapo version that's a soldering iron and plunger thing in one
    I've also got my decent soldering station in case it needs a little help.
    Byron C likes this.
  10. Byron C
    12 Apr 2002
    Cool, that'll be easier at least!
    Use flux, lots of flux!
  11. David
    7 Apr 2009
    Yes, flux the capacitors... um, wrong thread, maybe...
    I'll get my coat.
    The_Crapman, Arboreal and Byron C like this.
  12. Byron C
    12 Apr 2002
    I mean, sure... if you're desoldering capacitors you'll want flux...
    Just don't hit them with 1.21 gigawatts.
    David, The_Crapman and Arboreal like this.
  13. The_Crapman
    5 Dec 2011
    Will one 50ml bottle be enough?
  14. David
    7 Apr 2009
    Bottles? Where we're going, we won't need bottles!
  15. Arboreal
    21 Jan 2011
    Dad jokes galore, I love it! Keep up the good work lads :thumb:
  16. Byron C
    12 Apr 2002
    Yeah that should be fine. It can be a ballache to clear up flux, but it makes the job so much easier.
    LennyRhys and The_Crapman like this.
  17. The_Crapman
    5 Dec 2011
  18. David
    7 Apr 2009
    Mr T's mixed caps and missing comma is messing with my head. :lol:
    *Can't concentrate on keyboard!*
    The_Crapman likes this.
  19. The_Crapman
    5 Dec 2011
    He also got coffee in him. :worried:
  20. The_Crapman
    5 Dec 2011
    That's one board sorted anyway, now for the ducky..... PXL_20220517_182001934.jpg
    I have a problem :naughty:
    BeauchN and wyx087 like this.
