Scratch Build – In Progress Metaversa 02: Ada
Discussion in 'Project Logs' started by Nexxo, 21 Jan 2014.
  1. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Looks great.
    Maybe those fans have detachable blades?
  2. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    :eyebrow:
  3. Pranja
    Pranja Blackwolf
    18 Dec 2011
  4. Cheapskate
    13 May 2007
    White works too.:D
  5. Nexxo
    23 Oct 2001
    Nope, tried that. Feels like it would break before it yielded.
  6. Umbra
    Umbra What's a Dremel?
    18 Nov 2013
    You could use some, uh, artistic licence and make them so they sit on the edge of the centre support rather than on the fan, obviously they would not spin but it would eliminate any possible balance issues and they would still look very cool.
  7. ChromAnomaly
    ChromAnomaly What's a Dremel?
    7 Nov 2013
    Aw, and here I was hoping you might just remove the blades and machine your own out of solid brass :naughty:
  8. Umbra
    18 Nov 2013
    With some fans like an Enermax I have you can pull the entire fan out in one piece for cleaning, no circlips, just the centre spindle pushes into the mounting bush with a click, they can be quite tight to pull out, "I have never had relations with your fans so you do so at your own risk!" :thumb:
  9. Deblow
    Deblow Minimodder
    12 Dec 2013
    WOW, this is going to be EPIC, wish i had some metal working skills
    and the fans look really nice :thumb:
  10. jrs77
    jrs77 Modder
    17 Feb 2006
    They are not spinning at all, as they don't sit on the part of the fan that's spinning.
  11. Cheapskate
    13 May 2007
    Meh, You might not want to add any weight to the fans anyway. They might not spin if you get them heavy enough.
    -That's probably been said, but you are getting a LOT of comments, and it's hard to remember.
  12. Umbra
    18 Nov 2013
    If you go back a few posts you will see it was being discussed.
  13. siliconfanatic
    10 Sep 2012
    :read:
    And read it as in every single post, not just a quick skim-over. Do this and you'll find it's already been said and disproved.
    Why is it that I always jump on a chance to use that emote?
    I would quote it but my tablet refuses to highlight/select text, let alone copy/paste it.
  14. Nexxo
    23 Oct 2001
    OK guys, take it outside.
  15. Umbra
    18 Nov 2013
    Jeez mate get over it, you are obviously perfect and never missed a post :rolleyes:
  16. specofdust
    specofdust Banned
    26 Feb 2005
    Dude...it's so pretty.
  17. siliconfanatic
    10 Sep 2012
    Nah, nothing against you, I just really like using that emote.
    :idea:Also perhaps the fans use one of those modder nightmares called clips? If so, god be with you, you'll get them off, but they'll never stay on again :worried:
  18. Umbra
    18 Nov 2013
    I like that emote as well :read:
  19. Nexxo
    23 Oct 2001
    Do I have to call the Mods in here to clean up the thread? :eyebrow:
  20. Umbra
    18 Nov 2013
    Only replying in kind and pointing out what siliconfanatic said that I did, no abuse, just banter.
