News Micron on-track for GDDR5X mass production
Discussion in 'Article Discussion' started by Gareth Halfacree, 11 Feb 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. The_Crapman
    5 Dec 2011
    Are micron the only ones producing gddr5x, or are others such as samsung and sk hynix also going to be producing it? If they're only going into mass production in the summer then I doubt we'd see any new non-hbm gpus until q3 this year at the earliest.
  3. Harlequin
    Harlequin Modder
    4 Jun 2004
    JADEC only finalised the standard on Jan 22nd - and so far it does seem Micron are the first.
  4. rollo
    rollo Modder
    16 May 2008
    Dout there will be a massive demand for it, The costs to implement are just as high as HBM.
  5. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    Previous reports suggest it uses the same interface / pin-out as GDDR5, so the cost to implement should be minimal.
  6. Guest-16
    Guest-16 Guest
    Implementation should be no more than GDDR5.
  7. rollo
    rollo Modder
    16 May 2008
    Anandtech disagree with you on that, they say it requires a more complex board than gddr5 currently uses. That coupled with the extra cost will make it just as expensive.
    It's not something you will see in a low end board. I'd be surprised if Nvidia did not use it as a difference between the price ranges 960 equivalent gddr5 970/980 equive gdd5x. With only the TI and Titan models getting HBM.
  8. Harlequin
    Harlequin Modder
    4 Jun 2004
