Mk.6 EMP -Experimental Modular Project-
Discussion in 'Project Logs' started by Captain Slug, 20 Jun 2005.
  1. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    Um, not having to go find a screwdriver or keep track of thumbscrews was the main goal. And coming up with a visually interesting mechanism to accomplish that. It really had nothing to do with speed.
    It does the same thing as the latching mechanisms used on mass manufactured cases, but I think it's more stylish.
  2. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    um, people don't mod / make cases to save time (or money).
    Looks cool, expect a knockoff soon. My only concern would be the durabiliity of the rubber bands (most degrade rather rapidly).
  3. Captain Slug
    25 Nov 2001
    The rubber bands are temporary as I needed to test the mechanism. I'll probably use elastic string instead which will be much more durable. Trying to find small enough extension springs was proving difficult.
  4. Sphering
    Sphering What's a Dremel?
    31 Oct 2006
    Nice work there... Looks very cool in action
  5. Captain Slug
    25 Nov 2001
    Not alot going on right now. The past few days have been filled with playing and cleaning. It's seriously premature, but I have begun planning my next project. :D
  6. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    that mechanism for the panels looks great. And fast too, nice job on that!
  7. Captain Slug
    25 Nov 2001
    Well, I think I've hit a wall on this project that I won't be able to get over until I have outside help. Here's the basics of the problem at hand concerning the Plug-bus circuitry.
    1. There is NO WAY I can drill 700 tiny holes accurately using manual methods.
    2. I do not know anyone with free access to numerical drilling equipment that would be able to help me get the holes drilled
    3. I don't have the funds to pay for a commercial service to do the work (which would involve over $1000 in labor for one set)
    I have a friend in Sweden who is working on getting his CNC equipment up and running but I'm not sure when he will be finished. If he falls through then I'll have to start setting aside the funds to go with a commercial solution.
    On a positive note there are very few machining tasks left to do. Basically I just need to machine an intake duct and make the case handles.
  8. R_H
    R_H What's a Dremel?
    10 Jun 2006
    How many projects have you done? Can you post links to others that you've done but haven't posted here?
  9. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Captain, it is completly up to you (of course) but I can drill those holes at no cost. I do a lot of my own personal electronic projects and have the tools set up for my meathod drilling those holes.
    If you have the PCB's already made and just need them drilled, it would only take me a few days if you want to send them to NC and it would only cost you the price of shipping.
  10. Captain Slug
    25 Nov 2001
    A few examples: http://www.captainslug.com/mod.html
    and
    http://forums.bit-tech.net/showthread.php?t=93199
    I've completed over 30 custom PCs since 2000, but not all of them were documented.
    That is an awesome offer and I will be taking you up on it. I'll get to work on the etching once I can make a trip to my friend's print shop to get the circuitry templates printed out.
    I have 13 single-sided 3oz copper boards so I'll be able to send you two sets of boards should you need a spare if you run into any problems.
  11. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Np. Are you going to have these etched before or after they are drilled?
  12. Captain Slug
    25 Nov 2001
    Up to you. I can ship them to you etched or with just the laserjet ink transfer on them.
  13. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    After looking back at board layouts that you posted, it would be better to have them etched. That way when drilling, I can make sure there is still enough copper around the holes to hold the solder.
  14. Captain Slug
    25 Nov 2001
    Alright. I'm going to start working on the etching tomorrow morning after I visit my friend's printing shop and get the transfers made.
  15. Tyinsar
    26 Jul 2006
    @ Soulmage: :thumb:
  16. Captain Slug
    25 Nov 2001
    Got the printing for the plug-bus etch done. Radioshack (and all similar stores within a 20 miles of where I live) no longer carries etchant so I'm going to order some tonight.
    And a goody came in the mail! A 5gpm Rotameter, and it's pretty large (8 inches tall).
    I'm very familiar with these thanks to my part-time job, and they usually cost $100 to $200 apiece. And measurement ranges useful to watercooling are not typically measured with these, but I managed to find one on eBay for $30. It will be going in the loop inbetween the radiator and the pump inlet.
    What's great about using this kind of flowmeter is that it will have almost NO effect on the flowrate because it offers very little restriction. It's also really unique looking and for some reason I just love anything analogue. The only downside is that it only works oriented one way since it relies upon gravity. But should I need to invert the motherboard I would also have to rearrange where the radiator is so it's not very likely that I will do so without making a number of other changes to the loop at that point in time.
  17. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Just as a suggestion, after you transfer those to the PCB, you might want to fill in those larger hole with permenant marker so that when you etch it, that whole pad will still have copper. That way when I drill it, you still have a solid pad to solder to.
  18. Captain Slug
    25 Nov 2001
  19. Dustin
    Dustin What's a Dremel?
    22 Apr 2006
    Ultra's never going to make it even as half as good as your case mate and they are doing this in a whole factory,dont bother.
  20. Darkened
    Darkened Minimodder
    28 Feb 2004
    Lol, you should sue their arses for stealing your plans :hehe:
    Any progress on Mk.6?
    Janne
