Windows MOH Airborne [System Reboot]
Discussion in 'Gaming' started by mwvirk, 3 Aug 2008.
  1. mwvirk
    mwvirk What's a Dremel?
    21 Jul 2008
    Hello friends,
    i have original dvd or moh airborne, but when i insert it in my dvd ram my system automatically reboots and i was not able to install game.
    i load the dvd immediately after switching on the pc and when ms windows was ready then i opened the windows explorer and explore the dvd and ran easetup.exe and manage to install game and install available patch even updated my windows installer to 3.1 but still having the same problem... and still when i load the dvd it runs autorun and i can just see a blue screen (just a second time) and then system reboot automatically...
    please help me to find out the problem... i cannot turn off auto run just for 1 dvd... there should be a proper solution...
    thnx
  2. GoodBytes
    20 Jan 2007
    Hello, Welcome to bit-tech forum.
    What operating system are you using?
    If you are using Vista,
    Right click on Computer > Properties, then select "Advance system Settings". Click on the the "Settings" button within the last group called "Startup and Recovery". From there simply unchecked the box on "Automatically restart".
    If you are using XP, From the control Panel, open the "System Properties" which is somewhere I forgot.
    Look for the "Startup & Recovery" group, and click on "Settings" then uncheck the box called "Automatically restart"
    From there tell us the blue screen error message (if any).
    So far, possible problems are:
    - Memory related
    - Virus or malware damaged important Windows files
    - Bad disk copy, request a disk replacement.
  3. mwvirk
    21 Jul 2008
    thnx for ur reply...
    i am using xp pro 32bit sp2
    i got ur point and i not worried about virus or corrupt windows and hard disk problem...
    only thing which scare me from ur reply is "MEMORY"
    i have just installed new windows with sp2 after formatting my HD so there is no virus or disk problem...
    i have also installed MOH AA + SP + BT and MOH PA and when i was trying to install MOH airborne then only i got this problem... which i managed to install as i told u before...
    then i have also installed crysis and playing with no problem....
    all above installed games including airborne are running smoothly but problem is only then autorun starts after loading airborne dvd
    if there is problem like what u said then why only airborne dvd is deducting it... why not other games dvd or movies dvd.....!!!!
    anyway i will also disable the setting as u said and will give u screen short of blue screen shortly... thxn again
  4. p3ri0d
    p3ri0d What's a Dremel?
    9 Jul 2008
    Try giving us the autorun of your dvd? (autorun.ini or autorun.inf) Not sure it'll do something but...
    Anyways, you're only possibilities left are memory failures or bad cd copy, even though the latter is more possible then the other one
  5. PhenomRed
    PhenomRed What's a Dremel?
    3 Dec 2007
    This happened to my friend, I just laughed at his rebooting computer while i played with no problems
  6. p3ri0d
    9 Jul 2008
    He could be that friend :p
  7. mwvirk
    21 Jul 2008
    i am also thinking of using the same dvd to some other computers .... before doing any stunts....
  8. PhenomRed
    3 Dec 2007
    Try using it in a shared DVD drive on the network. That being said though, it still reset my friends PC :p
    Also, if you hold down Shift it should prevent it from auto-running, correct me if i'm wrong
  9. mwvirk
    21 Jul 2008
    working fine on other system (pc & even laptop)
    disable setting in auto shutdown to see blue screen and here it is the message:
    stop: c000021a {fatal system error}
    the windows subsystem system process terminated unexpectedly with a status of 0xc0000005 (0x7c911629 0x0069dcdc).
    the system has been shut down.
    any comments pls...
  10. mwvirk
    21 Jul 2008
    any comments pls...
  11. mwvirk
    21 Jul 2008
    any updates pls...
