Displays Monitor cleaning
Discussion in 'Hardware' started by donok, 15 Mar 2014.
  1. donok
    donok Every Little Helps .....
    16 Feb 2011
    Hello
    So my beloved Dell U2711 needs a clean. I dust it every now and then but need to clean the screen.
    what do you suggest ? a special wipe ? a special cloth ?
    thanks for the help
  2. Comrade Woody
    Comrade Woody Obsolete
    14 Mar 2011
    The U2711 manual states:
    "To clean your antistatic screen, lightly dampen a soft, clean cloth with water. If possible, use a special screen cleaning tissue or solution suitable for the antistatic coating. Do not use benzene, thinner, ammonia, abrasive cleaners, or compressed air."
    I've always found a damp cloth to be fine for cleaning monitors, I've never needed any special wipes or solutions. Just make sure it's only very slightly damp, not soaking wet, and wipe the screen gently. The cloth should be clean and soft, don't use anything abrasive.
  3. GoodBytes
    20 Jan 2007
    Yup. That is what I use. Just a microfiber cloth with delicious tap water dampen.
    What I use do, is use the monitor at a high brightness level for a moment to warm up before cleaning. Then when it comes to cleaning, I turn off the monitor and wipe gently the screen, if there is any stuck dirt I wipe multiple time. As the monitor is warm, it drys immediately as you wipe.
    Assuming you don't have hard water (high amount of minerals in the water), the screen should look like new, once your are done. No streaks, no nothing. :)
    I tried a bunch of cleaning product, while they all pretty much worked great on my non glossy laptop, sadly they all left streaks that I can't polish off, on my Dell monitor. Must be the coating. Using the damp cloth with water fixes that.
    If you have very dirty screen, you can add in a pot, with tap water, a bit of white vinegar (I said a bit! It should not really smell vinegar. If you room smells vinegar, you clearly put too much), and dampen your cloth with it, and use that to clean. The vinegar will help get the incrusted dirt in the plastic texture out, without damaging the panel coating, also it helps removing grease and helps repeal dust afterwards.
    It's all part of the thousand and one usage of white vinegar in the house hold :)
  4. donok
    16 Feb 2011
    Great tips guys. Thanks. Will give it a try
  5. GoodBytes
    20 Jan 2007
    Wow I screwed up the English on my post. Sorry about that, I just woke up when I typed it. Fixed now.
  6. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Good old tap water. I use an old glasses/lens cleaner bottle for a light mist so I don't ever over dampen the micro-fibre cloth. Just make sure the bottle and pump are emptied and dried after. Don't want no stanky water next time.
  7. acemodder
    acemodder Official Antec Rep
    13 Apr 2013
    Antec sell special cleaning wipes and sprays for monitors. Check them out :)
  8. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Microfibre cloth lightly moistened with some water. I used to use 'muc-off' screen cleaner, but it was quite expensive at £3 or £4 a time. I found that it honestly isn't any better than using a microfibre cloth with water though. I do use the microfibre cloth I got from muc-off, it really is quite an excellent cloth.
  9. law99
    law99 Custom User Title
    24 Sep 2009
    This is why I like the old smaller models. They still fit in the washing machine which also means you can tumble dry them. Bonus.
  10. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Don't forget to iron them on a high setting afterwards to get rid of any creases in the screen :D
    Seriously, though - you can't really beat water. It might take a few passes with different parts of the cloth if your screen is really dirty - but it's a damn sight cheaper than any cleaning products you can buy.
    law99 likes this.
  11. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
    I have a U2711 and I use a microcloth and Klear Screen periodically...
  12. Parge
    16 Jul 2010
    I use petrol, followed by the standard 'controlled burn'. Really gets rid of the grime.
    law99 likes this.
  13. law99
    24 Sep 2009
    Ah yes. The Italian tuning.
  14. donok
    16 Feb 2011
    Thats for all the info guys. Just want to take care of the monitor the best i can
