Displays Monitor help
Discussion in 'Hardware' started by OmightyOne, 2 Dec 2011.
  1. OmightyOne
    OmightyOne Minimodder
    7 Nov 2011
    Hello all,
    I've been looking into getting a another monitor to sit alongside my current 22" Samsung 3D monitor in a vertical position so that it can display stats, temps server status etc. without having to alt tab all the time.
    I'm on a budget of around £130 and preferably around 20" and wall mountable.
    I've been looking at the LG IPS225V Flatron led monitor but can’t seem to find any reviews on it. I wonder if any of you lot have seen or currently using one?
    Or can anyone else recommend a similar monitor.
    Any help would be great!
    Many Thanks
    James
  2. GoodBytes
    20 Jan 2007
    Get the LG IPS231P-BN 23inch instead. fully adjustable stand and non glossy. Reviews are good. A good entry level IPS screen.
    Alternatively, you have the Dell U2212HM (22inch 1920x1080), or the Dell U2312HM (23inch, 1920x1080). The Dell one is a bit better, and have Display Port, DVI and VGA as input.
  3. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    The LG is around the £150 mark i have one its a great monitor!!!!
  4. OmightyOne
    7 Nov 2011
    Do you think it can be wall mounted? if i take the stand off would i be able to attach a wall mount?
    many thanks
    James
  5. GoodBytes
    20 Jan 2007
    The Dell monitor (all model mentioned) and the LG IPS231P-BN 2 are VESA mount compatible.
