Hardware MSI 990FXA-GD80 Review
Discussion in 'Article Discussion' started by Lizard, 26 Aug 2011.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    Any screenshots of the EFI BIOS?
  3. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    So it turns out a rubbish product. A bit sad. Normally MSI knows how to do stuff
  4. randis1981
    randis1981 What's a Dremel?
    4 Nov 2010
    msi roca solida en intel
  5. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    ya this was looking a lot more previous when it went against that asus board but to see the whole review sorta a bummer.
    Im leaning towards the Gigabyte 990FXA-UD7 now.
  6. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    It occurs to me that reviewing these boards with Phenom processors is a bit irrelevant - surely they're designed for Bulldozer instead. Will you guys be going over some of these boards again when the new CPUs are out?
  7. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Does the pic show a different Motherboard? I really does not look like the 24 pin power is any where near an inch away from the edge. The only "realy" negative about is that it is not at 90 degree angle to the MB.
  8. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    The comment in the review is for the 8-pin EPS12V socket, not the 24-pin ATX socket, which is in a pretty reasonable place.
Tags: Add Tags
