News MSI teases mini-ITX gaming gear
Discussion in 'Article Discussion' started by Gareth Halfacree, 22 Nov 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. Tyrmot
    Tyrmot Minimodder
    12 Mar 2008
    This is a cool idea, I hope more manufacturers get on board with this. Miniaturising rigs has to be next way forward surely..?
  3. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Glad to see more single 8pins PCIe power connectors instead of 2x 6pins. The cooler on that GPU look similar to the one used on Asus DirectCU mini (GTX670 / 760). Wouldn't be surprised if it was in fact the same :D. Only the fan blades profile seams different.
  4. Jack_Pepsi
    Jack_Pepsi Clan BeeR Founder
    24 Apr 2006
    To me this is excellent news.
    Like Tyrmot said, I really hope this inspires and motivates other manufacturers to follow suit. I regret going mATX with my upgrade and with cases like the Bit-Fenix Phenom coming out, I really wish I had waited. Still, by the time I'm ready to upgrade again we'll have an array of decent mITX components... hopefully.
  5. Guest-16
    Guest-16 Guest
    I was gonna say, haven't I seen that design someone before? :idea: I suppose if you can't innovate, imitate.
  6. GuilleAcoustic
    26 Nov 2010
    I guess there's not so many possible solutions (except going watercooling). But Asus was first :D.
  7. Jack_Pepsi
    24 Apr 2006
    Turns out it's a GTX 760 that lil card.
    :D
  8. GeorgeStorm
    16 Dec 2008
    That card does look quite a lot like the Asus card :p
    Not that I mind, more companies looking to do that kind of thing sounds good to me.
  9. Guest-16
    Guest-16 Guest
  10. Jack_Pepsi
    24 Apr 2006
  11. faugusztin
    11 Aug 2008
    And the CPU socket again makes it unusable for any air cooler bigger than stock cooler, with the rare exceptions like HR-02 mounted wrong way, or small coolers like NH-U9B.
    What is so hard to understand in the fact, that if your CPU socket is next to the PCI-E slot, you will block the PCI-E slot with big coolers in bigger ITX cases like Bitfenix cases, or if you want to use coolers like NH-L12. :wallbash: So it is still only ASUS or EVGA for me (at least i don't feel the need to upgrade from my Sandy/Ivy Bridge ITX systems so far).
  12. CowBlazed
    CowBlazed What's a Dremel?
    9 Dec 2005
    Would hate needing to upgrade or replace the GPU at some point and having very little options.
  13. Combatus
    16 Feb 2009
    Phenom comes in micro-ATX too ;)
  14. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    The thing I love about the Prodigy is the board position which isn't the same with the Prodigy M or the Phenom. To me they both look a mess inside with that orientation.
  15. Weekly_Estimate
    Weekly_Estimate Random bird noises.
    1 Feb 2010
    Yes but the question is!! will that board work or will it just light up and look fancy?
    msi /faceplant
  16. Xir
    Xir Modder
    26 Apr 2006
    You're right...
    There wouldn't be a miniITX version of the Gryphon on the way, would there? :D
    (Also, is Bit ever going to test a Gryphon?)
  17. Jack_Pepsi
    24 Apr 2006
    Yeah, I thought about replacing my Arc Mini with the Phenom but I really want to change my set up to mITX, just it's all frivolous spending I can't afford.
