UPDATE:- Guess What...It lives!!! It was the CPU Max temps after Intel burn test 46*C with a nice low Vcore of 1.168 --------------------------------------------------------------------------------------------------------------------- After fighting with the carriers today, and finally getting my new platform at stupid O clock (19:45) which should have been here before noon today. It now gets worst... Starting to put the beast together; Added the water block, which screws in nicely to the original LGA2011 bracket. The GTX 580's getting put in place... Connecting the pipes up... SSD's in ready to go in... PCIe 6 pin plugged into the board to give the PCIe lanes some more juice. Also the floppy power connector is connected to the mobo to give the Dimm slots some extra juice aswell. 8pin and 4pin CPU adaptors added. So all is well up to this point, So I now load the loop full of water, quick leak test, which was fine. Now I decided to power it on...As soon as I pressed the power button, I heard sparks and saw flames coming from the heatsink on the motherboard. I quickly pulled the plug and investigated...This is what I found, and now the motherboard is dead. I don't know if it has taken anything else out with it... UPDATE: -22/12/2011 14:10 New board has come but...no post. The PC is just jump starting. On, Off, On, Off...I've check the memory with only having 1 stick in Dimm Slot D1 as per the manual. With no luck. I have used every stick to determine it isn't the ram. I have taken my GPU's out, and added a spare 8600 GFX card, which is my tester card. Still no post. I have tried using just the 8pin CPU adaptor without the added 4pin. No post. Now on my motherboard, it has LED's to indicate problems, it shows the red LED light on the CPU, but I don't know where it would just come on prior to pushing the button, as it will not post...CPU dead? Simon.
Ah dude that suck's just hasn't been your today today has it? Hope you managed to get it sorted without to much hassle
I'm sure Asus/Scan will sort you out ok? Although, It is an absolute kick in the nuts when stuff like this happens huh.
What a ball-ache. That board was probably always going to die on the first person unlucky enough to switch it on. Have yourself a good laugh or cry then send it back. Also, a nice stiff drink wouldn't go amiss round about now.
I can't see how anything there could have been your fault. RMA it, and hope it goes quickly. I feel for you.. seriously. If you were throwing together a cheap and cheerful 1155 rig you'd have been annoyed, but a £300 motherboard is a different matter. It's for this reason that I broke the rule of a lifetime, and got Scansafe (or whatever it's called) fitting insurance on my SB-E gear.
What the hell could have caused that?! Looks like some dodgy soldering or something causing a short. Sucks man, that would have been some sick benches.
