Scratch Build – In Progress N+1H²0...Project end/Final shots
Discussion in 'Project Logs' started by bugbear974, 3 Sep 2011.
  1. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    Much better, glad we could help :thumb: Plus, with that much RAM, you don't need that much pagefile anyway
  2. bugbear974
    bugbear974 What's a Dremel?
    31 Jul 2011
    Thanks you much Mosquito for your help. :thumb:
  3. bugbear974
    31 Jul 2011
    Hello everyone this is the result of my SSD in crystaldisk, I'm not really satisfied, but it is much better than my DD acien. I am always doing my best to improve it, but I'm running out of ideas. The updates are all done, I think the firmware is the only thing I would change but not for me because my SSD turns the OS.
    By bugbear974 at 2012-01-02
    All your opinions to improve this will listen. So tell me what you think about it because apparently I could reach 500MB / s read and 400MB / s write.
  4. bugbear974
    31 Jul 2011
    Here are the pictures as you hope. Give me your opinions and comments.
    Thank you to everyone who helped me in this project a little crazy. In the active participation of suppliers. And to you and for your comments, without which I would not have found the courage to finish this.
    Stay tuned for new mods.
  5. TotalGaos
    TotalGaos Stainless steel.. hmm..
    16 Dec 2007
    Awesome! I particularly love those switches, very cool. Those pictures got way better, too!
  6. bulldogjeff
    2 Mar 2010
    That is very, very, impressive. It's neat and tidy, it's laid out well, the colours work well, everything about it is right. A big well done dude...Top modding
    It's the 2nd of January and already Ive seen 2 builds that should be in the MOTY this year.
  7. bugbear974
    31 Jul 2011
    Thanks you ;)
  8. bugbear974
    31 Jul 2011
    Thank you very much, I am especially inspired by many things here. :clap:
  9. l3p
    l3p www.^.nl
    1 Nov 2010
    Looks much better bugbear!
    Since the coolant looks green anyway with the UV leds ... why don't you use Acid green like I did, Then it will really glow :)
    About the ssd, do you have AHCI on in the bios?
  10. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Oy looks very good. I like the soft feel to the glow.
  11. bugbear974
    31 Jul 2011
    Hello L3P it is easier for me to get the Feser coolant blue (less time to get on highflow) however yes it would be a good idea to incorporate the green to see the effect.
    As for the AHCI so on rampage extreme III are equipped and took care of the set. My bios is up to date as the Intel and AHCI. I made ​​all the changes to windows (sleep, indexing ect ...) and crystal disk info in my two SATA drives are well 600. I do not know where to look now that I have done all his. But I'm pretty pleased with myself if I should compare it to my old computer.
  12. bugbear974
    31 Jul 2011
    Thanks you much.
