LOL Name that bog seat...
Discussion in 'General' started by Vault-Tec, 17 Jan 2018.
  1. Vault-Tec
    30 Aug 2015
    Probably the strangest thread I have ever posted. Please can some one tell me what sort of toilet seat this is. Ebay is great. It cracked about a year ago on the right, then last week cracked on the left and it's pinching my ass :D
    It is not a bolt through. I know that much. So yeah, I've no idea about modern bogs.
  2. Kronos
    Kronos Multimodder
    6 Nov 2009
    So how does it fix to the toilet pan?
  3. Vault-Tec
    30 Aug 2015
    I don't have a clue mate, hence the thread.
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
    Can you not put your hand round the back and have a fumble?
    Vault-Tec likes this.
  5. VipersGratitude
    VipersGratitude Multimodder
    4 Mar 2008
    :naughty:
    The_Crapman and Vault-Tec like this.
  6. Vault-Tec
    30 Aug 2015
    lmao tried that fella. However it fixes to the crapper must be at the hinge area. There is no bolts or holes anywhere on the bog. Modern tech eh? bloody thing !
  7. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Can't tell exactly from the pictures but it's probably a top fixing toilet seat with blanking plates/covers covering bolts/screws with an compression expander that expand into the holes when tightened.
    Like these.
  8. adidan
    25 Mar 2009
    Magic. It uses magic.
    You need potions and some runes.
    The_Crapman likes this.
  9. Vault-Tec
    30 Aug 2015
    I'm pretty convinced it must fix from the top yeah. Just need to find one now.
  10. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    Its a Teresa May.
  11. Big Elf
    23 Apr 2009
    It'll be fixed from underneath and with luck it'll use plastic thumbscrews. I don't know what they call that square design unless it's just 'square'
  12. Mister_Tad
    27 Dec 2002
    That's exactly what it is. The same seriously puzzled me not long ago when one of mine started to get a bit loose, and I found there were no wing nuts on the back.
  13. Journeyer
    Journeyer Minimodder
    31 Aug 2006
    Why bother with a new one? Fix it like a man! Duct tape is your friend. :D
    (Also, if you're going to photograph a toilet in its open state; remember to flush first... ;) )
  14. Vault-Tec
    30 Aug 2015
    It's bleach man.
  15. adidan
    25 Mar 2009
    Have you found your ablution solution?
    Kronos likes this.
  16. Kronos
    Kronos Multimodder
    6 Nov 2009
    I think he is sitting and thinking about the issue.
    Vault-Tec and adidan like this.
  17. adidan
    25 Mar 2009
    Ruminating while evacuating?
  18. Vault-Tec
    30 Aug 2015
    Can't order one now. Going away on Monday 'cause it's my Bday next week. Will order one when I get back :)
    I can't duct tape it. The structures that hold it up have basically collapsed, so pardon the pun but it's pissed any way. Last thing I want is it snapping and me ending up on the floor with plop coming out :D
  19. Kronos
    Kronos Multimodder
    6 Nov 2009
    Have you figured how to get the old one off yet?
    A toilet seat as a birthday gift, go for it?
  20. Vault-Tec
    30 Aug 2015
    Will figure that out next week. For right now I'll take a pinched ass lol. I don't want to break it, then not have one. Toilet is proper freezing haha.I think the thing in the middle is a clip or something you lever upward. So that may be a cover and how you get it off.. Not sure..
