Modding Nanoxia Project S Water-Cooling Build: Part Three
Discussion in 'Article Discussion' started by Dogbert666, 22 Nov 2016.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. The_Crapman
    5 Dec 2011
    Very nice :thumb:
  3. Neutronman
    Neutronman What's a Dremel?
    19 Aug 2016
    Looking good. I've just started to put together a shopping list for my next build and this will be my first build with Rigid tubing. I tried acrylic a few years back and just could not get a decent bend.
    Perhaps I'll post my build here after completed.
  4. stealth80
    stealth80 Minimodder
    1 Feb 2015
    Looks great, apart from one eye sore! Could that 8 pin atx cable not have been routed behind the board ? There's even a cable management hole for it :D
  5. Combatus
    16 Feb 2009
    There is, but it's completely blocked by the radiator - not even enough room for the cables to thread through!
  6. stealth80
    1 Feb 2015
    That's a shame, looks great non-the less:thumb:
  7. Combatus
    16 Feb 2009
    Thanks :) The cable looks much better in person. If I could go back I'd maybe route it under the motherboard but the ModMesh cables probably aren't that flexible. Still it's otherwise a great case.
Tags: Add Tags
