Watercooling need advice on water cooling a cooler master cm690 nvidia edition case
Discussion in 'Hardware' started by Chriscogley, 23 Aug 2011.
  1. Guest-56605
    Guest-56605 Guest
    1155 or 1366?
    Assuming your going the Intel route
    Chriscogley likes this.
  2. Chriscogley
    Chriscogley New Member
    13 Jul 2011
    yeah going intel wantong a 1155??
    or of u know both i could decide once i look at the boards
  3. Chriscogley
    13 Jul 2011
    i'm thinking of a asrock p67 extreme
    what you guys think?
  4. Guest-56605
    Guest-56605 Guest
    To quote the bit-tech review -
    "The P67 Extreme4 may not be the quickest P67 motherboard we’ve seen, but it’s within just a few per cent of the frontrunners' performance. Add to this its long list of useful features and extras, and you have a solid motherboard that would make a sound base for an LGA1155 PC.
    There are some areas for concern, though, such as the warm-running chipset and the EFI idiosyncrasies, which mean that the board falls just short of winning an award. If you’re in the market for a P67 motherboard then we'd still currently recommend the B3 revision version of the Asus P8P67. However, with all the B3 boards we've got in the labs, it's definitely going to be worth checking back over the coming weeks to see how the contenders from other large manufacturers fare"
    http://www.bit-tech.net/hardware/motherboards/2011/05/05/asrock-p67-extreme-4-review/1
  5. Chriscogley
    13 Jul 2011
    Thankyou very much 23RO_UK you know where to find your stuff
    think i will be going for the msi p67A or the asus p8p67 there both a lil better and with the same kinda price range
  6. Guest-56605
    Guest-56605 Guest
    Your welcome :thumb:
    Personally I'd go for the ASUS P8P67 as it has the better EFI :)
  7. Chriscogley
    13 Jul 2011
    okay was thinking about getting that one anyway
    so thankyou for helping finalizing my decision
    i have done alot of research and gonna go for the asus
